Fuel Filter
Old Oct 17, 2007 | 04:24 PM
baskplaya120's Avatar
baskplaya120
Default Fuel Filter
Yo guys,
I realize this is probably going to sound very dumb but how do you bleed the fuel lines ive looked everywhere and cannot find how to do this so im thinking it must be pretty obvious but im at a loss .. thanks in advance for you help
Old Oct 17, 2007 | 04:27 PM
Baron von Munchausen's Avatar
Default RE: Fuel Filter
Pull the fuel pump fuse, start the car, and let it run until it dies.
Xemeth's Avatar
Xemeth
To take the fuel filter off?Don't bother. A bit of fuel will pour out from the lines, but not much. But you're going to need a fuel line removal tool. I don't think they have the quick release tabs on them. My GT doesn't at least.
Old Oct 17, 2007 | 04:32 PM
Derf00's Avatar
Derf00
Gentleman's Relish
You can skip 'relieving the fuel pressure' if your car has been sitting overnight. If not, you should pull the pump fuse as described and turn the car over for a few seconds to relieve the pressure. You can also disconnect the inertia switch in the trunk for the same effect.
Popping the fuel lines off after turning off the car without relieving the pressure will result in fuel spray because the system is stillunder pressure.
99-04 will require a fuel line disconnect tool for about $5 from any parts store. You want the 3/8" size.
Old Oct 17, 2007 | 04:39 PM
baskplaya120
thanks boys i appreciate it a lot ill do it tomarrow morning i believe
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
