V6 turbo question
Old Oct 18, 2007 | 10:34 PM
taterchiprobb's Avatar
taterchiprobb
Default V6 turbo question
I would like to put a turbo on my 2006 v6 mustang. I am looking at either sts or powerhouse(i live really close to powerhouse) but i found out that recently one of my buddies had an 11psi turbo installed on his gt. He scattered the engine on the road because it couldn't take the forced injection. We're talkin pistons crank. everything went boom. I dont want this happening to me considering i dont exactly have wads of cash to spend. Can anyone tell me anything about if this happens often or what psi would be safe..if any?
Old Oct 18, 2007 | 10:40 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Default RE: V6 turbo question
They normally say 6-8psi is safe with fuel mods.
3.6 without fuel mods -
I don't think anybody makes a turbo for the 99-04 v6 anymore however.
Old Oct 18, 2007 | 10:44 PM
taterchiprobb
fuel mods.. meaning like what injectors and fuel line? or higher octane?
Old Oct 18, 2007 | 11:11 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
ORIGINAL: taterchiprobb
Injectors & Pump
Old Oct 18, 2007 | 11:22 PM
raz54's Avatar
raz54
Did your buddy retard the timing? If he didn't you get detonation and that'll blow it up real fast.
Old Oct 19, 2007 | 08:21 AM
LilRoush's Avatar
LilRoush
Sounds like someone installed a turbo without a tune (or at least a good one).
Old Oct 19, 2007 | 12:57 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
ORIGINAL: LilRoush
Or forgot his fuel mods and leaned it out....
Old Oct 19, 2007 | 01:58 PM
taterchiprobb
i'm not sure. i don't think he had any fuel mods. which is adefinite problem it seems,but he had the install done by powerhouse so i can't see how they would miss that. unless they make you do your own tuning. but with thefuel mods.. injectors and a new pump. is that it? there won't be any like gasket changes or anything? cuz i wondered to myself if those stock gaskets on the engine could take f.i. especially the little v6 ha. and how much does a set of new injectors and a pump cost ya?
Old Oct 19, 2007 | 03:06 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
450ish....
Old Oct 19, 2007 | 03:54 PM
28HopUp's Avatar
28HopUp
MF Administrator
Rygen told me that 10psi should be fine from a PH turbo on a daily driven 4.0L. He was running a PH turbo (unsure of psi) and a 75-shot to run 10.9's. Dual power adders are tough on our 4.0L's, but the PH set-up is nice.
You will also need supporting mods. If you are going with a power adder, then forget beefing up the 7.5" rear - go directly to a 8.8" GT take-off assembly. It will be money wasted otherwise. You'll need LCA's, UCA, better tires, and perhaps add'l suspension mods to fully take advantage of the newfound power.
