Differential Fluid Change
Old Oct 20, 2007 | 02:32 PM
ProvingGrounds's Avatar
ProvingGrounds
Default Differential Fluid Change
So I just finished changing the differential fluid and I mus say that the location and angle of the fill plug is completely retarded!
To my understanding, the diff case takes about 1.75qt to be properly filled; however, I was unable to get more than abour 1.3qt in there?!
Have you had this problem before? and how bad is it if I drive with less than 1.75st in there?
Old Oct 20, 2007 | 03:05 PM
GlockPants's Avatar
GlockPants
Default RE: Differential Fluid Change
It is retarded, but I used a hand pump to get it in there...a lot easier.
Old Oct 20, 2007 | 03:19 PM
ProvingGrounds
How much were you able to get in there before it started overflowing?
Old Oct 20, 2007 | 07:36 PM
ProvingGrounds
Anyone?
Old Oct 20, 2007 | 09:26 PM
GlockPants's Avatar
GlockPants
all of it...the recomended fill level doesnt even fill up the entire diff...Im sure you can find something at a hardware store to put the rest of the fluid in that is cheap. What i used looked like a giant syringe with a hose instead of a needle.
Old Oct 20, 2007 | 11:46 PM
sabin_chicago's Avatar
sabin_chicago
just fill up to the cap whole
wait a bit and then try to put more
Old Oct 20, 2007 | 11:53 PM
Slim2none's Avatar
Slim2none
I just did mine this week lol terrible. I used this, http://www.ted-kyte.com/3D/Pictures/Oil%20Can.jpg
Didnt take all to long, only thing isyour hand will cramp up here and there.
Old Oct 21, 2007 | 02:58 AM
cominus's Avatar
cominus
So did you notice any difference after the fluid change?
Old Oct 21, 2007 | 08:34 AM
Xemeth's Avatar
Xemeth
ORIGINAL: cominus
Do you notice anything after an oil change? Diff fluid change is preventative maintenence. It doesn't really do anything for performance.
Old Oct 21, 2007 | 11:29 AM
mooses's Avatar
mooses
ORIGINAL: ProvingGrounds
I had exactly the same problem. I actually think I got a full quart in there, and then another third of a quart before it overflowed - so just about ~1.3 quarts, too. I tried a few days later, and I still couldn't get anymore in there. I drove it around for about 3 months, and then when I did my transmission swap, I tried adding more and it still wouldn't hold anymore. I've left it alone since then, and I haven't had any problems.
