pulling pistons without pulling engine
Old Oct 20, 2007 | 09:47 PM
jdanbarnes's Avatar
jdanbarnes
Default pulling pistons without pulling engine
Ok, so I have a straight 6 and not a v-6, but a six isa six. . . sort of. Anyway, I need to do some work on a piston, has anyone ever tried to pull a piston without pulling the engine? My 65 coupe has enough room, I have to drop the tranny for some work, I can drop the oil pan, take the heads off, think I can get the piston all the way out? Thanks guys!
Old Oct 20, 2007 | 09:52 PM
cobra232's Avatar
cobra232
Default RE: pulling pistons without pulling engine
if you can get the oil pan out then yes you can remove that particular piston. unbolt the rod cap and slid some rubber tubing over the bolt as to not score the journal and tap the rod/piston out through the top with a wooden rod. easy as that
Old Oct 20, 2007 | 11:17 PM
raz54's Avatar
raz54
You may have to unbolt the motor mounts then jack the motor up to get the pan off. Watch out for any hoses and radiator fan though.
Old Oct 21, 2007 | 08:29 PM
HARFORD's Avatar
HARFORD
can the 98 mustangs have the pistons pulled out without the block being pulled?
Old Oct 22, 2007 | 02:40 PM
cobra232's Avatar
cobra232
ORIGINAL: HARFORD
yes. same as above procedure
Old Oct 22, 2007 | 02:43 PM
l_shizzle_l's Avatar
l_shizzle_l
Why don't you want to pull the engine? It would be easier that way, gravity would be working with you rather than aginst you.
Old Oct 22, 2007 | 03:00 PM
MUSTANG042004's Avatar
MUSTANG042004
ORIGINAL: l_shizzle_l
Yes it easier but it such a hassle to take out the engine. Especially for only one piston.
Old Oct 22, 2007 | 03:24 PM
HARFORD's Avatar
HARFORD
not everyone can pull the engine, or have somewhere to put it.
Old Oct 24, 2007 | 02:33 PM
jdanbarnes's Avatar
jdanbarnes
My problem is getting a hoist and having somewhere to put the engine. I would love to pull the engine out and paint the engine compartment and stuff, and I might. I might also do that down the road too, just needed some options. Thanks guys.
Old Oct 24, 2007 | 07:57 PM
MantaDreams's Avatar
MantaDreams
ORIGINAL: jdanbarnes
buy a folding hoist from Harbor Freight for about $140.00.
http://www.harborfreight.com/cpi/cta...emnumber=93840
If you don't want to buy an engine stand, then set the engine down on a milk crate (I have a 302 minus the heads sitting on one right now.)
but you'll want a stand. http://www.harborfreight.com/cpi/cta...emnumber=32915
these things are cheap import tools butwill work for the infrequent home user.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
mungodrums
Oct 7, 2015 04:01 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
zachary1988
Sep 4, 2015 03:04 PM
