Problem.....
Old Oct 29, 2007 | 03:10 PM
niseyd07's Avatar
niseyd07
Default Problem.....
So last week my fuel pump went out on me. i had it replaced and an oil change and while i was at it i welded up my exhaust manifold, was having that annoying noise..... then took a trip to san antonio which is about hr and half from were i stay. on my way back home the car started hesiating. i pulled over check water oil, everything seemd fine. i took off again about 5 miles down the road it started to hesitat again the more i push to accelerate the more is hesited i did smell a little gas. was about 30 mins from home so i jus decieded to let the car cool down, i did this 30 mins later i took off and it was fine the rest of the way. any ideas?
Old Oct 29, 2007 | 03:32 PM
FBCBEER's Avatar
FBCBEER
Default RE: Problem.....
something is overheating, but unfortunately I couldnt tell you. Take it to autozone or something to have the codes checked out.
Old Oct 29, 2007 | 04:12 PM
Systemreset's Avatar
Systemreset
Did your engine light come on? if not check for leaks and make sure they didnt mess anything up when they put your header back in.
Old Oct 29, 2007 | 05:34 PM
niseyd07's Avatar
niseyd07
no leaks and yes my engine light turned on, however it dosnt show that my car is overheated.
Old Oct 29, 2007 | 07:30 PM
Systemreset
Do what FBCBEER said and go get the codes check. Something must have been damage or not hook up properly
Old Oct 29, 2007 | 10:39 PM
butch86's Avatar
butch86
do you smell rotten eggs? could be a cat going bad or heating up on you
Old Nov 26, 2007 | 12:44 PM
niseyd07's Avatar
niseyd07
k so my car finally gave out.... fuel cleaner did not work... changed plugs with dino new wires.. then pulld all data from my car and found three active codes clys 3, 5, 6, had misfire. Then checked the injectors with dio test, also checkd screen in tank was ok and put new air filter..... Turns on smells gas,i have a big exhaust leak, so im gna need some new hearder, so think of putin some performnce one now that i have to replace the stock ones, also bought an ignition coil pack.... anyone have any suggestions on what headers i should get, i have flowmasters. or if and one has some for sell, let me know
Old Nov 26, 2007 | 12:47 PM
niseyd07's Avatar
niseyd07
o and yea my fuel gauge isnt workin any suggestions now that im workin on my car might as well get that fixed as well.
Old Nov 26, 2007 | 12:56 PM
niseyd07's Avatar
niseyd07
anyone have a link on how to replace the ignition coil?
RichM1983
Feb 8, 2013 10:17 PM
rleey07
Aug 16, 2010 08:31 PM
kane1983
4 Cylinder NA and Turbo
Mar 5, 2010 10:32 PM
93nitrousLX
Aug 25, 2008 08:28 PM
cruiser
Mar 14, 2008 08:23 PM
