clutch problems
Old Nov 24, 2007 | 03:10 PM
aj552's Avatar
aj552
Default clutch problems
ok.....i have a 2002 v6, my problem is every time i press the clutch my RPMS go up, it started 3 weeks ago. is this a sign that the clutch is going out................the car has 100000 miles and it is still the original clutch.
plz help.
Old Nov 24, 2007 | 03:19 PM
l_shizzle_l's Avatar
l_shizzle_l
Default RE: clutch problems
You must baby that clutch, my factory one went out at 70k. I'll have another one soon once i get my engine in.[sm=badbadbad.gif]
Old Nov 24, 2007 | 03:31 PM
aj552's Avatar
aj552
do have an idea how much it will cost me to change it??.....im looking to replace it with another stock clutch.
Old Nov 24, 2007 | 03:51 PM
l_shizzle_l
I think mine cost my uncle arround 1k
Old Nov 24, 2007 | 04:57 PM
mustangman02232's Avatar
mustangman02232
depends on whos doing the work
i baught one for my toyota from napa for $100and its been in for about 5k hauling ~3000 lbs worth of scrap metal without any problems
if you want something good id look into a centerforce or spec
Old Nov 24, 2007 | 05:34 PM
NeoTokyo's Avatar
NeoTokyo
To have a shop install the clutch for you is about $250 or so.
The cost of the clutch depends on what you want to get. A Spec Stage III is something like $450.
You will also need the flywheel resurfaced which is about $50 dollars. I did mine myself.
You can install the clutch yourself and save that cash but you will have some really tight working conditions and you will have the lower the whole trans down. Frankly $250 is worth it unless you have the tools and experiance to do it.
You will also need a new throwout bearing and a pilot bearing. The throwout is about $20 dollars and the pilot is something like $10.
Being that you have such high milage on your car this is a great time to also replace your clutch fork and pivot ball. Prices on those are hard to get ahold of because they can be a hard part to find. But both shouldnt cost you more than $75 combined.
While your doing all this you can also upgrade to a UPR heavy duty clutch cable, firewall adjuster and aluminum quadrant. That will run you about $90 dollars, summit sells and identical kit for $60. I dont know if you want to get the clutch cable though. Mine was nearly identical and snapped last week. I re-installed the stock clutch cable and have better performance out of it now... So I am only running the quadrant and firewall adjuster, about $40-50 bux for the two.
Best of luck, a new stronger clutch will make the car scream, it really helps to lower your times on those somtimes jerky take-off's.
-Eric-
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Brandonfilipponi@yahoo.com
Sep 12, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
