i decided on a turbo.
Old Nov 25, 2007 | 07:43 PM
stangant's Avatar
stangant
Default i decided on a turbo.
well i have decided on a turbo setup on my car. I will custom make the whole system myself, it will be hidden for the most part. i will have a diagram up soon of what im planning. my question is what size turbo would be the best.
Old Nov 25, 2007 | 07:48 PM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: i decided on a turbo.
Well for inlet diameter I have no idea, but one that makes around9 psi would be best unless you're upgrading your internals, 11 psi maximum on an otherwise totally stock car.
Old Nov 25, 2007 | 07:51 PM
92lxsleeper's Avatar
92lxsleeper
grab a garret T3 or a Warner Ishi off of a 2.3L turbo, thunderbird, mustang svo or merkur xr4ti. they already push 15-18 psi depending on the setup stock, and you can put a softer wastegate actulator on it to run at a lower boost.
Old Nov 25, 2007 | 07:52 PM
LilRoush's Avatar
LilRoush
Garret PT61 is a great choice fora single set up on the 3.8L.
stangant's Avatar
stangant
well i eventually want to buy a 3.8l block and build it up then plug it in, all forged and race ready.
Old Nov 25, 2007 | 07:53 PM
LilRoush's Avatar
LilRoush
ORIGINAL: 92lxsleeper
T3 and the T3/4 hybrids are too small unless you are going to run a twin set up.
Old Nov 25, 2007 | 07:54 PM
stangant's Avatar
stangant
well i was thinkin twin but im goin single so i can go sleeper lol.
Old Nov 25, 2007 | 08:00 PM
LilRoush's Avatar
LilRoush
If you go twin, the T3/4 hybrid match it your best bet for a stock to mildly modded motor.
Old Nov 25, 2007 | 09:29 PM
stangant's Avatar
stangant
here are some general ideas that i am going to do. now i do not think that the intake will be there and also the intercooler and piping will be in all black.
Old Nov 26, 2007 | 03:03 PM
HornyHornyHippo's Avatar
HornyHornyHippo
I wouldnt paint it black. It would look better but wouldnt the black color b more prone to absorb heat then a lighter color?
