cigarette lighter plug not working
Old Dec 5, 2007 | 11:43 AM
neo8222's Avatar
neo8222
Default RE: cigarette lighter plug not working
ORIGINAL: EaZy DuZ iT
its the fuse 100%
yeah well i kinda already knew that so im wanting to know WHAT fuse it is cause i dont have a manual (and dont say the burned one cause non are) so a pic with a arrow would be nice
Old Dec 5, 2007 | 03:25 PM
crash's Avatar
crash
BrandofPoop
Go to kragens or autozone or advanced auto parts, what ever you have where you liveand buy a chilton book for mustangs. it should have eveyrthing in there.
Old Dec 5, 2007 | 04:03 PM
neo8222's Avatar
neo8222
ive looked at the auto stores. no chilton.... just haynes[:@]
Old Dec 5, 2007 | 04:09 PM
blackstalion232's Avatar
blackstalion232
its either #17 or 18 under the hood its one of the minis thats what it is on my 98
Old Dec 6, 2007 | 08:24 AM
neo8222's Avatar
neo8222
i can test fuses by taking a multi meter and checking resistance on the tops of them while ignition is off right?
Old Dec 6, 2007 | 02:24 PM
crash's Avatar
crash
BrandofPoop
ya you could do that to check em
Old Dec 6, 2007 | 02:51 PM
neo8222's Avatar
neo8222
alright well i got under the steering wheel and checked everyfuse with my multi meter and found the bad one. problem solved later on ill take a pic and point it out for other that have a similar problem
Old Mar 24, 2022 | 07:53 PM
thund3rbolt's Avatar
thund3rbolt
Originally Posted by neo8222
ok, when the cigarette lighter port wasnt working on my car i figured it was a fuse so i checked them ALL! non are burned out. so i removed my shift **** and took off the boot and trim and checked the conenctor with a Volt meter and it wasnt getting power. so my question is, what else could it be? the thought that maybe the fuse was missing had crossed my mind so if anyone can tell me which fuse it is and its rating it would be greatly apreciated. the other thought that crossed my mind is a broken wire but im hoping it isnt that so for now lets assume its not, k?
Did you ever solve this? I have the exact same problem and went through the exact same steps. Fuse is fine, connector okay, and the crazy thing is... sometimes it works and sometimes it doesn't. The power point in the console never works all the time but in dash is a 50/50 chance. Notably, after I drive again for awhile it starts working.
djbigskrilla
Sep 20, 2022 01:04 AM
unit91
Aug 31, 2015 10:27 AM
Itzjoe
Aug 26, 2015 08:15 PM
Hogquad
Aug 23, 2015 05:26 AM
overnight89
Aug 22, 2015 09:02 PM
