Replacing Clutch - What else should be done?
Old Dec 15, 2007 | 01:08 PM
rallyred01's Avatar
rallyred01
Default Replacing Clutch - What else should be done?
I think I'm going to go with the Spec Stage 1 clutch, I'm just wondering if I should get my flywheel resurfaced, or get a new one. I'm at 84k miles. Also should I replace the throwout bearing? And how would I go about checking to see whether the TO is bad or not?
Old Dec 15, 2007 | 01:15 PM
mws96's Avatar
mws96
Default RE: Replacing Clutch - What else should be done?
most clutch kits come with the throw out bearing and input shaft bearing, so you might as well replace everthing.
Old Dec 15, 2007 | 01:42 PM
rallyred01's Avatar
rallyred01
ORIGINAL: mws96
It doesn't look as if it's included here, tell me if I'm missing something:
http://www.americanmuscle.com/spec-s...v6-clutch.html
And as far as the flywheel?
Old Dec 15, 2007 | 02:37 PM
tims 88 4's Avatar
tims 88 4
order it directly from spec they have great customer service this is the way i did imine they even helped my pick the clutch to fly combo correctly since i got a gt stage 2 clutch and a v6 standard flywheeel
anywho back on subject the kit directly from spec comeswithnew hardware and a new pilot bearing andt/o bearing for a very easy install
a tip for the man repacing his clutch make sure you have plenty of freon or laughing gas and a slide hammer with a hook on it to get the pilot bearing out they are pita
tims 88 4's Avatar
tims 88 4
get a new flywheel
5.0muscle
Jan 11, 2016 01:17 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Emblazoned
Sep 3, 2015 10:45 PM
