Rear brakes
Old Dec 22, 2007 | 09:28 PM
nitrous36's Avatar
nitrous36
Default Rear brakes
Getting ready to do my rear brakes in a few days. Wondering if there isaway to turn the piston back in without buy/renting the tool? From what I understand theyre a b1tch to turn back in the caliper,and thats with the tool. But Ive heard there is a way to do it without the tool (not easier by less expensive) by using something like a regular pair of pliers. Is this true?
Old Dec 22, 2007 | 11:08 PM
02MustangV6DD's Avatar
02MustangV6DD
Default RE: Rear brakes
Use needlenose pliers. Its only a b!tch If your a puss and have never done brakes on a car. Good luck. Any more Q's ask
Old Dec 22, 2007 | 11:24 PM
nitrous36's Avatar
nitrous36
Well I only done front brakes. Never did the rear so never delt with screw in pistons. Cant wait to get to it.
Old Dec 22, 2007 | 11:40 PM
02MustangV6DD
Ehh, not so much fun. I always have a problem with the e-brake cable. No matter how many times i do it
Old Dec 23, 2007 | 01:24 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
You can usually get the tools for free from some parts stores, you just have to leave a deposit.
Old Dec 23, 2007 | 10:16 PM
neo8222's Avatar
neo8222
ORIGINAL: 02MustangV6DD
+1 that cable had me cussing so much. I was about ready to cut it off with bolt cutters then I yelled at it and it went on.... so if u cant get it on just do like me and tell it GET THE ^&#%$ ONTO THE &#^% ROTOR!!!!!!!!!! and itll work
Old Dec 24, 2007 | 01:04 AM
IDRISCKY's Avatar
IDRISCKY
ORIGINAL: RyansQuick6
hes right
at autoparts i deposited $100 dollars and they gave me the full set, returned it and got my money back. pretty sweet deal if you ask me. i tried to toil with needle nose and two screw drivers and bah, not worth it. just fork over the deposit money, its a lot easier, i assure you.
Old Dec 24, 2007 | 05:15 AM
RyansQuick6
Reverse Gear Member
Oh, if you wanna make the drive, I have the $100 tool from Snap-On lol.
Old Dec 24, 2007 | 10:07 PM
SilvrStang's Avatar
SilvrStang
Tool is expensive to rent,its like 45 bucks ****ing ridicilous. Just get 12 inch pliers from auto zone for like 10 bucks and turn them. But before you turn them, loosen the nut in the back of the caliper above the springs to release some of the oil out when you're compressing it back in there. If you dont theres a chance you'll **** up the caliper. I forgot what its called so itd be nice if someone helpd out.
Old Dec 24, 2007 | 10:25 PM
Cryptostorm's Avatar
Cryptostorm
if you put a large c clamp on them and have someoen else crank it while your turning with the pliars they go in a lot quicker and easier (obviously make sure the part of the c clamp that pivots is on the side your turning)
