engine swap
Old Dec 23, 2007 | 09:00 AM
bloup69's Avatar
bloup69
Default engine swap
i have a 1983 mustang gl and i have had it about a year now and the 3.8 with a 2 barrel motorcraft carb has plenty of power stock but im a v8 person and i wasn wondering if any v8s would swap over easy perferably fuel injection
Old Dec 23, 2007 | 10:14 AM
cobra232's Avatar
cobra232
Default RE: engine swap
a 5.0 will go in fairly easily but you would need quite a bit of stuff like engine,radiator,wireing harness ECU GT guage cluster ands beef up that 7.5 rear with 3.73 gears and a detroit truetracor swap in an 8.8 all in all you looking to spend $3000 on the swap. having a donor car like a nice 89 GT would make things alot easier.
you may need to swap trans too. if you have a C5 it could probably be built up to C4 specs to hold the V8 and it would be wise anyways as V6 trans internals were weaker than the V8 trans too. the bellhousings are the same 3.8 to 5.0.
or you could build your 3.8. www.moranav6racing.com has cams,headers,4bbl intakes ported heads,pistons for your year 3.8 and it wouldn't be hard to get 220-240rwhp out of your 3.8 which is more than a stock 5.0 puts out
Old Dec 23, 2007 | 10:42 AM
LilRoush's Avatar
LilRoush
Where are you located - I'm in Minnesota.
I've got a 5.0L I'd trade you for a 3.8L with a carb. I've been lookingfor one. Mymotor is in a 1990LX right now, runsvery strong with no issues at all. I'd toss in everything you'd need to swap it in if it would work out.
Old Dec 23, 2007 | 10:46 AM
bloup69's Avatar
bloup69
i got a late 1095 to 1991 linclon ans a donner car could i use the stuff off it?
Old Dec 23, 2007 | 10:48 AM
bloup69's Avatar
bloup69
im located in oklahoma i havent decide yet if i want the engine swap or just sell the car and find something else but looking for someone intrested right now
Old Dec 23, 2007 | 10:52 AM
LilRoush's Avatar
LilRoush
I just sent you a PM. If you want to sell the 3.8L motor, let me know.
And to answer your question, the 5.0L for most other applications drops right in. I know some had different oil pans, so you might have to swap that to a mustang pan prior to dropping the new motor in.
Old Dec 23, 2007 | 02:27 PM
cobra232's Avatar
cobra232
ORIGINAL: LilRoush
ueah the lincoln pan won't work. he is going to have to swap in a stang pan
Old Dec 23, 2007 | 09:21 PM
bloup69's Avatar
bloup69
ok i'll check into it
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
mdj89
Sep 6, 2015 11:08 PM
zachary1988
Sep 4, 2015 03:04 PM
