Motor Oil question, and performance question
Old Jan 7, 2008 | 11:24 PM
Slothcat's Avatar
Slothcat
Default Motor Oil question, and performance question
I got my oil changed today in my car for the first time since I got it...I waited about 4000 miles :\ I was going to get it done, but I just never had the time with as much as I work... Anyway, I got some Royal Purple in there, since I heard that's some pretty good stuff. I was just wondering if that's true, because my oil change costed $82, and if there's not any kind of difference, then I'd rather not spend that much haha.
Also, I'm wondering if I bought a diablosport predator tuner, what kind of horsepower gains would I get?
I looked on americanmuscle.com and I can't seem to find one for a 2004 v6, on there..so do they even make one?
And, when I got my oil changed, the guy scanned something on my door, and it showed up that I have a 3.9L V6..I thought it was only 3.8.
Old Jan 7, 2008 | 11:41 PM
djay's Avatar
djay
Default RE: Motor Oil question, and performance question
You have a late 2004 model, hence the 3.9L V6. The tuner can get you some so-so HP gains, depending on your knowledge of tuning!
Old Jan 8, 2008 | 12:06 AM
Slothcat's Avatar
Slothcat
So what's the max hp gained you think I could get if I had a good tune?
Old Jan 8, 2008 | 12:27 AM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Max would be probably 13-20 and that would probably be on the dyno.
Btw:
Once you go Synthetic you have to stick with it
Old Jan 8, 2008 | 01:13 AM
Slothcat's Avatar
Slothcat
Well, does it really help with gas mileage and with horsepower?
Old Jan 8, 2008 | 06:47 PM
cobra232's Avatar
cobra232
ORIGINAL: VCS_SSSTANG
Btw:
no you don't. today's synthetics are fully capable of being blended with natural crude/parrifin based oils.
i run this. cheap advance auto oil with 1 quart as the last quart of Lusac oil conditioner.
on high mileage engines i will run the last quart as a quart of ATF. ATF is high detergent and scrubbs sludge deposits out of an engine. this is only a 500-1000 mile oil interval then change it with fresh oil and 1 bottle of lucas.
Royal Purple is good stuff too butlucas is alittle less pricey and IMO everybit as good. Hi-Tach is decent stuff too as is Redline and Drydene oils.
cheap advance total grip filter is a good filter too. stay away from fram filters they have the cheapest internal design. Advance and purolator are better. K&N filter=waste of money and is not needed to filter down that small of a particle. i do like their integrated nut on the end of the filter though and i use in on my heavy service diesels where the filter gets tight as hell
Old Jan 8, 2008 | 06:55 PM
02MustangV6DD's Avatar
02MustangV6DD
Btw:
Why is that? I use Valvoline 5w-20. Change it every 3000 miles. I would like someone to explain to me how synthetic is better? Wat ways/reasons/facts.
Old Jan 9, 2008 | 01:36 PM
727SixxBanger's Avatar
727SixxBanger
Royal Purple is one of the best motor oils you can get, i work at a jiffy lube and there isn't a significant difference from most full synthetics from royal purple, but theres a difference, also im pretty sure V6(2000 like mine) might be same as all other V6(99-04) and take 5W-30, im not looking at it so i could be wrong, you also dont have to stick with full synthetic oils, but if you are going full synthetic now, then change to a conventional or regular oil, then decide to go back to full synthetic you should also get an engine flush to get the gains from synthetic oil .
Old Jan 9, 2008 | 02:54 PM
mustangman02232's Avatar
mustangman02232
ORIGINAL: 727SixxBanger
i unforutuately work at jiffy lube to (friday is last day thought )...............
STOP LEARNING THEIR BULL **** WAYS!!!!!!!!!!!
unless you have a heavily boosted/modded engine there is no real reason to run synthetic unless you drive alot of miles, to which you can run 5-10k on some oils, but most filters wont last that long, all the "engine flush" is is keroseane and doesnt do ****, i used to run full synthetic and went backit hasnt made a single differance
99-00 is 520 01-04 is 530 or the other way around, dont remember exactly
royal purple is good if you dont mind spending $15 for a quart, and for 99% of people, your not even going to have the car long enough for it to make a differance
btw do you run "winter oil" in your car[8D]
Old Jan 9, 2008 | 04:34 PM
blknismo180's Avatar
blknismo180
mines a 2000 and it says to run 5w30 i'm not sure about the other
