acceleration problem
Old Jan 22, 2008 | 07:09 PM
  #21
red3.8_96stang's Avatar
red3.8_96stang
Default RE: acceleration problem
ORIGINAL: VCS_SSSTANG
ORIGINAL: 00StangV6
my cel stays on, took the converters off and didnt put two of the 4 sensors back in. i hope this is the problem and i promise you, i will never use any type of bosch products
And thats the other half of your problem.
He could be right , which 02 sensors did you leave out ? & did you bung up the holes or are they already blanked off ?
Old Jan 22, 2008 | 07:46 PM
  #22
00StangV6's Avatar
00StangV6
the two closest to the motor were put back in but the back two wasnt. i took off the converters which the back two were screwed in and replaced it with strait pipe.from wat i understand it wont hurt anything jus makes the cel stay on but i could be wrong. theyve been out for atleast a yr. dont see why it would all a sudden start afecting the car now
Old Jan 22, 2008 | 07:56 PM
  #23
ESG-642T's Avatar
ESG-642T
Buyer Beware
ORIGINAL: 00StangV6
You need MIL elims.... or a tuner to turn the rear 02 sensors off.
Old Jan 22, 2008 | 08:07 PM
  #24
red3.8_96stang
ORIGINAL: 00StangV6
O.K. then, but now since your CEL is on, you probably dont know if any new codes have appeared ?
This could give you a clue as to what is going on. I'd suggest, go to Autozone & pull the codes, then post them back here. We might be able to help you better, instead of you spending money on wild guessing ?
Old Jan 22, 2008 | 08:18 PM
  #25
00StangV6's Avatar
00StangV6
can i do that odometer trick that shows ur rpms and speed and stufff digital. that shows u coedes right
Old Jan 22, 2008 | 08:21 PM
  #26
00StangV6's Avatar
00StangV6
the new plugs did nothing, jus a huge waste of time. i didnt know u could put so many curse words in one sentence and make complete sense
Old Jan 22, 2008 | 08:25 PM
  #27
ESG-642T's Avatar
ESG-642T
Buyer Beware
ORIGINAL: 00StangV6
What plugs did you get?
Old Jan 22, 2008 | 08:26 PM
  #28
00StangV6's Avatar
00StangV6
i was gonna get motorcraft but didnt wanan spend 5$ a plug to find out thats not the problem. i got ngk plugs
  #29
red3.8_96stang
ORIGINAL: 00StangV6
No, to get codes with OBD2 you need a scantool. Some autostores will do it for free. It will also tell you that your rear 02 sensors are not working.
Old Jan 22, 2008 | 08:30 PM
  #30
00StangV6's Avatar
00StangV6
i dont even wanna drive my car anymore. i used to enjoy driving it now i jus wanna beat the s**t out of it and push it off a cliff
