kit from supersix
Old Jan 27, 2008 | 01:55 PM
mustangcrazy87's Avatar
mustangcrazy87
Default kit from supersix
The adapter plate from supersixmotorsport.com...that plus the supercharger...is that all is needed. I have heard you need new injectors, fuel pump, MAF, Throttle Body, and more. Someone please clear this up for me.
Old Jan 27, 2008 | 02:07 PM
HornyHornyHippo's Avatar
HornyHornyHippo
Default RE: kit from supersix
[ol][*]6 - 42lb injectors with correct connector for 99-04[*]310lph pump[*]MAF Extender (use your factory MAF and this will keep it from pegging and allow proper tuning)[*]VMP PCV Delete Kit[*]Set of 6 AWSF-22C Spark Plugs (2 steps colder than stock)[/ol]Just some basics
Old Jan 27, 2008 | 02:32 PM
02MustangV6DD's Avatar
02MustangV6DD
IDk his username, but her sells the full kit. LILRoush or someone will be along and tell ya. DEF. Worth it!!
Old Jan 27, 2008 | 02:44 PM
itschristorres8's Avatar
itschristorres8
no one sells the full kit quite yet
at last 39lb injector you'll need
you'll needa cobra throttle body with the m112 as well as the intake
I WOULD NOT! use the stock MAF for a set up like that
geta BA3000 MAF from VMP or a 90mm MAF
310lph fuel pump for anything over 300rwhp or that area
depending how low you go on the boost you wont need step 2 colder
1 step will be fine some 764 Autolites if you plan on over 8psi then 103(autolite) or Tr-6 NGKs will be fine
also a dyno tune for sure
Old Jan 27, 2008 | 07:52 PM
jthorn9's Avatar
jthorn9
The Godfather
ORIGINAL: HornyHornyHippo [ol][*]6 - 42lb injectors with correct connector for 99-04[*]310lph pump[*]MAF Extender (use your factory MAF and this will keep it from pegging and allow proper tuning)[*]VMP PCV Delete Kit[*]Set of 6 AWSF-22C Spark Plugs (2 steps colder than stock)[/ol]Just some basics
+1, a tuner isn't a bad idea either for getting that thing tuned right after the install.
Old Jan 27, 2008 | 09:18 PM
itschristorres8
lol reading HornyHornyHippo list i just notice thats straight from VMP's website lol
oh boy
Old Jan 27, 2008 | 09:24 PM
amrcnidyot's Avatar
amrcnidyot
ive got a really good start on one and due to some issues i have to sell it. click the link in my sig!! its a really good deal for everything that you get. not only that but ive done all the work for you.
Old Jan 27, 2008 | 09:28 PM
HornyHornyHippo
ORIGINAL: itschristorres8
oh boy
Even when i delete lines it redid the 1-4 list format for me! Haha, it was easier then pie.
Old Jan 27, 2008 | 09:29 PM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
contact nathan (mysteed) over on 3.8mustang.....he is getting the whole kit ready to sell
and you would need....
atleast 39lb injectors
310lph fuel pump (for 99-04)
cobra maf
cobra tb
cobra plenum
definately a tune!!
Old Jan 27, 2008 | 09:49 PM
l_shizzle_l's Avatar
l_shizzle_l
New idler pulley setup
re-routed collant hose
