Gt Rear Axel
and if you think you may go with nitrous or a blower in the future you will need an 8.8 at that point anyways. if not then a posi on the 7.5 will be fine
yes you can find entire 8.8 assemblies for cheap. i saw for 650$ the other day a 8.8 rear end with 31 spline axles and 4:10's installed on craigslist. way too far of a drive for me to want to pick it up though and shipping would suck.
I have done both to my cars and i highly recommend doing a whole axle swap. It was much easier imo...all you gotta do is lower the rear take off the control arms and pull it out and replace it.....changing the internals on a rear can be very tricky and also dangerous.....go with the axle swap
well i found my 04 gt 8.8 with a 3.73 for $250 at a swap meet at beech bend...but i have also seen them for $800.....but you want to make sure you get a rear end with a 3.55/3.73/or 4.10 gear in it becuase if its any higher than those then you would just be gaining posi. You would eventually want to put a lower gear in it then you would have to mess with it internally.
ORIGINAL: Vtghost
Ok I Found A Cheap T-Lock On Ebay
Will THis Make Me Posi? And Is That All I Will Need?
then he says it not a posi. it isn't a posi. it's open and i am quite sure it isn't 31 spline and open
junk.
i don't like the T-lok but if your not planning on much power and have an auto you will be fine with the 7.5 t-lok
www.gefracing.com has the cheapest price on them
I Might Put A Turbo In This Spring..So I Might Have To Go With The 8.8 I Don't Want To Mess With Internals. But Don't You Have To Take The Suspension Off When Putting In The New Axle?
ORIGINAL: 02MustangV6DD
A T-Lock is a brand of POSI... That is for an 8.8 you need one for a 7.5. How much HP do you plan on going for?
Ryan has a Used T-Lock and 4.10 gears
I did recently find a stock rear end for my car though lol. I just need to pull it off the car I found and stick it in storage, the car also has the engine block I need for the 4.3 build. My stock of spare parts has dwindled down to 2 spare set of wheels (1 set of Bullitts, 1 set of 17" GT's), 17x10.5 Termi wheels with 315 NT555R's, stock headlights, projectors with a scuff on one, and little odds and ends. No more collection of rear ends, sway bars, springs, brakes, and all that other stuff. It's so sad
I plan to have my stock of spare parts built bac kup by summer though. I'm gonna go to auction friday and see if I can buy a couple of wrecked stangs and start gutting them. I'm stuck offshore right now though.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
