emissions...
Old Jan 30, 2008 | 09:51 PM
i_drive_stangs's Avatar
i_drive_stangs
Default emissions...
if i remove the egr and pcv and get them turned off in a tune will i pass an emissions test? i live and texas btw.
Old Jan 31, 2008 | 08:27 AM
i_drive_stangs
Default RE: emissions...
anyone know?
Old Jan 31, 2008 | 09:00 AM
H473R's Avatar
H473R
sry i dont know the answer to your question, but may i ask, why are u wanting to take them off?
i know on my old s10 he egr valve went bad, so i just took it off, plugged it up and what not, and it ran fine, but we didnt have emmissions tests here in florida =/
Old Jan 31, 2008 | 09:12 AM
NoLiMiT06's Avatar
NoLiMiT06
I would think if you "Check Engine" light does not come on I don't see a problem but don't quote me on that
Old Jan 31, 2008 | 10:04 PM
i_drive_stangs
split port swap with windstar intake. i have read that you have to delete the egr, not so sure about the pcv, but i haven't heard of anyone doing the swap and keeping both.
Old Jan 31, 2008 | 10:27 PM
MantaDreams's Avatar
MantaDreams
ORIGINAL: i_drive_stangs
It depends on the county. If you are in one of the counties with an extended emissions inspection program, most certified inspection stations will not pass you with any CEL or SESL, no matter what the cause. Those testing machines are pretty sophisticated andinclude a code reader.And if you disconnect the battery or otherwise reset the computer, they will fail you until you have driven 50-100 miles after which the computer has completed its reset (again it better be reset with no errors). I live in Williamson county that has that extended emissions testing as part of inspection, they ding me for every little thing, so I've learned there's no getting around it.
The following is a list of safety items for all counties:
http://www.txdps.state.tx.us/vi/insp...classsubmit=Go
This next link tells you what additional emissions requirements are imposed on vehicles registered in specific counties where ozone (smog) is a problem:
Old Jan 31, 2008 | 11:27 PM
ramoyer1's Avatar
ramoyer1
Check out Vap.com for The windstar intake. They sell the kit and They keep both of them I think I am not sure i have messaged them and asked.
Old Jan 31, 2008 | 11:55 PM
alexr's Avatar
alexr
most counties that check emissions will not pass you if anything that is part of the stock intake/exhaust system is removed or missing and not replaced with an (C)ARB legal part. that includes removing EGR equipment, installing eBay intakes, installing O/R midpipes, and installing LT headers (most LT's are not EGR equipped).
Old Feb 2, 2008 | 08:06 AM
LilRoush's Avatar
LilRoush
You will not pass in texas. I lived there for four years and had all my emissions stuff on all of my Mustangs. The get the engine warm prior to testing to make sure the EGR opens properly. It will have an effect on your A/F raito, and they will be able to pick that up.
Old Feb 3, 2008 | 10:13 AM
red3.8_96stang's Avatar
red3.8_96stang
PCV is a vital part of the ventilation system, it also prevents "blowback" into the crankcase/valve cover, which could damage the engine.
As for the EGR, if you turn it off the EEC will not conform to relevant emissions standards, I'd think you'll fail for sure!
Steve,
