cams??
Old Jan 31, 2008 | 12:14 AM
whiterabit998's Avatar
whiterabit998
From: vids> http://vids.myspace.com/index.cfm?fusea
Default cams??
oh sorry i meant cam, im new to a v6...... im used to me old sohc 281.....
but any who, wouldn't a cam make alot of cheap hp??
Old Jan 31, 2008 | 12:17 AM
Flake6899's Avatar
Flake6899
Default RE: cams??
Can you install it yourself? If you can p&p the heads and intakes while you're at it.
Old Jan 31, 2008 | 12:23 AM
Bolkas4eva's Avatar
Bolkas4eva
Default RE: cams??
Have fun with that project
Old Jan 31, 2008 | 12:27 AM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Default RE: cams??
ORIGINAL: whiterabit998
Alot, like 15-20?
Old Jan 31, 2008 | 07:14 AM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
Default RE: cams??
It helped mine...and made it sound 100 times better too
Old Jan 31, 2008 | 07:15 AM
LilRoush's Avatar
LilRoush
Default RE: cams??
Cam isn't going to do much without giving the air more room to move in the intakes/heads. Do all at once and net yourself some real gains.
Old Jan 31, 2008 | 07:47 AM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: cams??
ORIGINAL: LilRoush
+1
Keep this in mind, the 3.8L does not respond nearly as well to mods as the 4.6L and 5.0 engines do. While cam(s) can add nice power on a V8 with little supporting mods, sixers need a little more secondary work.
But yea, if you can do everything yourself, then "cheap" power mod it is.
Old Jan 31, 2008 | 09:03 AM
H473R's Avatar
H473R
Default RE: cams??
ok installing isnt a big problem, but what all is involved with p&p work on the heads and intake?
Old Jan 31, 2008 | 03:40 PM
whiterabit998
Default RE: cams??
ehh i think i can put it in, but idk how to port and or polish..its right behind the water pump right?
Old Jan 31, 2008 | 03:44 PM
LilRoush's Avatar
LilRoush
Default RE: cams??
Cam is aft of the water pump ... think 5.0L missing two sparkplugs.
