Idle
Old Jan 31, 2008 | 07:53 PM
mstang420's Avatar
mstang420
Default Idle
Okay I did searching and people have a similiar problem.
When very cold my idle will be around 1,
but when i have been driving etc it will be like 600.
I heard there is a way to adjust the idle to make it higher? how do I do so?
sometimes it knocks from 600 down to 500 and makes the car shake a little, its annoying but doesn't happen too often.
thnx for the help!
Old Jan 31, 2008 | 08:22 PM
02MustangV6DD's Avatar
02MustangV6DD
Default RE: Idle
Auto or Manual? Year? I dont remember but i think mine is at 850ish? In the cold it always is higher when i first start it up.
Old Jan 31, 2008 | 10:01 PM
jpacetti's Avatar
jpacetti
Default RE: Idle
It could be your IAC (Idle Air Control) valve is not opening enough. If it was totally bad it would choke out your engine. You could try cleaning it with some carb cleaner. Maybe even replace the gasket. Could be your plugs and wires need replacing. Good luck.
Old Feb 1, 2008 | 12:32 AM
Fink's Avatar
Fink
Default RE: Idle
my car used to drop idle and shake a bit. this was only when i went to the city, 2 hours away, and had to sit at a red light. i changed my plugs and it fixed the problem. it is normal for your idle to be at a grand when cold, mine goes to 1250 for 15-20 seconds then drops down to a grand. normal idle rpm is around 750-850.
Old Feb 1, 2008 | 10:20 AM
mstang420's Avatar
mstang420
Default RE: Idle
im going to try replacing the spark plugs & wires thank you
Old Feb 1, 2008 | 11:16 AM
indisposible_teens's Avatar
indisposible_teens
Default RE: Idle
Just do some routine maintenance on it. Put some engine cleaner in it, new plugs, oilchanges etc. etc. stuff like this always helps your engine out. I basically need a whole tune-up on mine but that will have to wait for a month or so.
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
MacSerio
Sep 27, 2015 01:05 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
