The M112
Old Feb 13, 2008 | 03:56 PM
red02mustang's Avatar
red02mustang
Default The M112
Does anyone know if the stock block on a 2002 mustang with work fine with the M112 and with supersixmotorsports M-112 Adapter Intake Manifold?
Old Feb 13, 2008 | 04:09 PM
LilRoush's Avatar
LilRoush
Default RE: The M112
Themanifold/kit is designed to work with everything from a stock motor up to a fully built race-oriented set up. It will work great for you, and give you room to make more power down the line.
Old Feb 13, 2008 | 04:11 PM
flash20's Avatar
flash20
i always wanted to s/c my 6er but the lower intake wasnt out when i wanted to.
Old Feb 13, 2008 | 04:15 PM
Bolkas4eva's Avatar
Bolkas4eva
how much dose the S/C add from BONE STOCK
Old Feb 13, 2008 | 04:28 PM
red02mustang
I was kinda wondering that to and what is its max psi?
Old Feb 13, 2008 | 04:31 PM
FBCBEER's Avatar
FBCBEER
I havent seen any official numbers, but I hear that it should be around 270hp/280tq.
Old Feb 13, 2008 | 04:32 PM
robinson209's Avatar
robinson209
Before putting a M112 on what other preparations need to be made to a stock engine?
Old Feb 13, 2008 | 04:40 PM
FBCBEER's Avatar
FBCBEER
Basically, you need 42lb injectors and an SVT Ford Focus or similar fuel pump.
Other than that, you just need the m112 parts from supersix or from a 2003-2004 cobra.
Old Feb 13, 2008 | 05:15 PM
LilRoush's Avatar
LilRoush
Bone stock motorwill make just under 300 hp to the wheels. Stock Cobra blower pulley will spin about 10-12 psi (Nathan see's 10 psi with his, but has improved heads that don't restrict the flow). As for upper limits, I ran a 10% over drive crank pulley and a 2.76" blower pulley and was flirting with 20 psi or so. But none of my junk is stock, so it's hard to say what it would do on a bone stock motor until someone tests it out.
But yes, the kit and the upgraded fuel system is all that is needed.
bullet281s
Mar 20, 2008 01:12 AM
NYstang
Mar 5, 2008 10:14 AM
YAYITSJEWDAY87
Feb 13, 2008 01:02 PM
johnt2k7
Dec 22, 2007 09:44 AM
JP®
Aug 23, 2007 07:23 PM
