Rough idle
Old Feb 17, 2008 | 03:58 PM
wolfpack_freak's Avatar
wolfpack_freak
Default Rough idle
It's been doing it for about a month now, doesn't do it consistently, just every now and then when I first start the car. Doesn't do it when I'm stopped at a redlight or anything, just when I first start it. It almost gets to the point of dying, but doesn't. I had the oil changed about 2 weeks ago, thinking that might have something to do with it, but it didn't. Haven't messed with anything related to the fuel yet. Any advice on what it could be?
Old Feb 17, 2008 | 05:03 PM
Rusticgt's Avatar
Rusticgt
Default RE: Rough idle
You might try running some seafoam through it and see if that helps..... or some Lucas fuel system cleaner, you might have a injector thats parcially plugged. Or it could be your MAF sensor.
Old Feb 17, 2008 | 05:18 PM
wolfpack_freak
Alright, I'll try one of the first two, thanks.
Old Feb 17, 2008 | 07:10 PM
robinson209's Avatar
robinson209
I had the same problem too. Except my idle was high. It goes away when the car starts to warm up. I got fuel injector cleaner from wal-mart for like 4 bucks for 3 treatments. I used it once already and it is better.
Old Feb 18, 2008 | 10:14 AM
LilRoush's Avatar
LilRoush
Are you getting a check engine light?
Try pulling DTC and OBDIIcodes and see what comes up.
Old Feb 18, 2008 | 05:45 PM
wolfpack_freak
ORIGINAL: LilRoush
Try pulling DTC and OBDII codes and see what comes up.
Nope, no check engine light at all, just the rough idle.
Old Feb 18, 2008 | 05:57 PM
l_shizzle_l's Avatar
l_shizzle_l
Clean the iac, make sure your air filter or anything in the airway is good.
Old Feb 19, 2008 | 05:31 PM
wolfpack_freak
I just bought some fuel injector cleaner, I'll try that first.
Old Feb 19, 2008 | 05:48 PM
ayrton02's Avatar
ayrton02
Vacuum leak???... It wouldn't hurt to make sure all the vacuum tubes are connected good.
Old Feb 25, 2008 | 06:24 PM
wolfpack_freak
The fuel injector cleaner worked great, thanks for all the advice, if it starts doing it again, I'll check the other things mentioned.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
MacSerio
Sep 27, 2015 01:05 PM
