Injectors
Old Feb 20, 2008 | 12:48 PM
BWfVA's Avatar
BWfVA
Default Injectors
Where can I get Injector from 22 to 24 pounds for a N/A 3.8 in a 02.
Thanks
BW
Old Feb 20, 2008 | 01:09 PM
LilRoush's Avatar
LilRoush
Default RE: Injectors
Where did you get those numbers from? For 99% of the N/A 3.8s out there, stock injectors are more than enough.
VMP Tuning sells injectors.
Old Feb 20, 2008 | 04:06 PM
BWfVA's Avatar
BWfVA
Well it is my friends car and he swears that his injectors are going out and he wants to put in slightly bigger injector. I dont know any specs on the car. So if you want any specifics then I will have to wait till tommorrow
Old Feb 20, 2008 | 04:12 PM
l_shizzle_l's Avatar
l_shizzle_l
Have them cleaned and flowtested. I think it's like $100 or somethin, i bet that would be less than buying new ones.
Old Feb 20, 2008 | 05:11 PM
BWfVA's Avatar
BWfVA
Ok Thanks, I will tell him that. He says that it kinda misses going up hill.I think what is wrong with it is the crap plug wires he's got on there, but even he says they suck. Where could he go get them cleaned at. The reason why he thinks that the injectors are going is that the car has 127 thousand on it. Which isnt that much, but I dont know. So thanks for any imput, I was just trying to help him out by finding a place so he could get some injectors. I told him also that he needs a tune with the injectors but he wont listen to me. He assumes that he can adjust them with a Preditor tuner so can he. I always though that you had to be using factory injectors unless you had it preprogramed in
Thanks for the Help
BW
Old Feb 21, 2008 | 09:53 AM
LilRoush's Avatar
LilRoush
A miss could be so many other things. Injectors would be about #5 on my list of things to check. I'd look at the spark end of it first.
Old Feb 23, 2008 | 12:41 PM
BWfVA's Avatar
BWfVA
Yea I know what you mean I have told him a thousand time to check it, he uses the worst spark plugs. He buys into the gemics and they dont work to well most of the time. If he would just go with some reliable spark plugs and wires. Another thing is that he is just looking for a reason to buy some injectors
Old Feb 23, 2008 | 12:43 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
ORIGINAL: BWfVA
Tell him to join the site.
Buying injectors means getting a tune. +200 more. What plugs does he have? If he has anything with the word bosch you must hit him with a tire iorn and you tube it.
Old Feb 23, 2008 | 04:13 PM
cobra232's Avatar
cobra232
i agree. Autolite Copper 604's or single or double platinum AP/APP764'swith autolite premium wires and run a can of Seafoam in the fuel tank to clean the injectors.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
MacSerio
Sep 27, 2015 01:05 PM
mltdwn12
Sep 23, 2015 08:54 AM
