Big transmission trouble!!!
Old Feb 24, 2008 | 08:09 PM
v6stang07's Avatar
v6stang07
Default Big transmission trouble!!!
well i just installed my shift kit and now i cant get my tranny into gear........could this be due to a lack of fluid? I dont think so cause there is 8qts or atf in there but it isnt really registering on the dipstick? Still i dont think that is it......i believe that everything was reinstalled correctly and i dont know of anything that was left off. Any help would be much appreciated.
Old Feb 24, 2008 | 08:30 PM
97tunedmustang's Avatar
97tunedmustang
Default RE: Big transmission trouble!!!
When you say you cant get into gear do you mean the shifter wont leave park?, or that you get it into Drive and it acts like its in Neutral?
Old Feb 24, 2008 | 08:44 PM
v6stang07's Avatar
v6stang07
it wont really leave park....
i got it to go down into R but it never went into gear and i did hear a slight clang when i took my foot off the brake in R
Old Feb 24, 2008 | 09:06 PM
97tunedmustang
You may not haveinstalled the valve body correctly to the shift lever in the tranny. If you did not get it in the proper position on the valve rod it will not go into Drive. If you installed thevalve body corectly you should be able to run the tranny through the gears by hand. Since you're unable to do this i'm thinking there is a good possibility that this is yourproblem.Drop pan, Move lever and watch rod motion. see if you have shift lever rod hookedup correctlyto the rod in valve body
Old Feb 24, 2008 | 09:30 PM
v6stang07's Avatar
v6stang07
is the shift lever what the detent spring goes up against???? and is the valve rod the big main rod in the valve body??
Old Feb 25, 2008 | 11:16 AM
v6stang07's Avatar
v6stang07
bump
Old Feb 26, 2008 | 01:27 PM
deadcarnahans's Avatar
deadcarnahans
Drop the pan and look at the end of the shift valve. It should be engaged to the shift lever and move along with it.
You have to unbolt the valve body and lower it a bit to reset this junction.
Old Feb 26, 2008 | 02:39 PM
v6stang07's Avatar
v6stang07
aight yall thanks i think i got it now....the understanding at least i havnt had time to work on the car yet
CS2007
Jun 25, 2019 09:45 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
ChampInSD
Oct 2, 2015 04:55 AM
wraith777
Sep 28, 2015 10:49 AM
