rear end
Old Mar 7, 2008 | 07:49 PM
wdc 09's Avatar
wdc 09
Default rear end
ok so i still have the stock rear end in my 2000 sixxer
however im wantin to swap it out and throw in a 8.8 in gt rear end
so wut im wondering is if ne of u guys kno where i could get one for pretty cheap or if u just kno where one is, let me kno
and yes i already kno rather than doin a whole new rear end i could just do a differential swap
but id rather just do a rear end swap, dk y, just feel like it haha
so also is there ne thin else, like would i have to get a new driveshaft to match the rear end or is the stock one fine still or wut??
thanks guys
Old Mar 7, 2008 | 08:01 PM
Cmpfreak88's Avatar
Cmpfreak88
Default RE: rear end
For the 2000 it's best to go with the 99-04's because other years are different lengths and you'd have to have wheel spacers and such and some may have drum brakes if you get even older. Everything should match however I hear that one hole in a bracket needs to be enlarged. I'm planning on doing this swap soon, I have the rear end sitting in my garage, just need to seal up the pumpkin and pick up some friction modifier.
Old Mar 7, 2008 | 08:05 PM
wdc 09's Avatar
wdc 09
sorry i meant 8.8 in, fixed it, i knew yea i need a 99-04 rear end tho but ya, alright well thats really all i needed to kno was that it pretty much bolts up with only a couple things needed to b done, thanks
Old Mar 7, 2008 | 09:32 PM
cobra232's Avatar
cobra232
please this isn't text messaging. type full words. it's free
Old Mar 7, 2008 | 09:37 PM
wdc 09's Avatar
wdc 09
yea thanks for the help but im lookin for info on the rearend not my typing skills thank u very much
if i wanted somethin to tell me how to spell everythin proper i wouldve gone to mircrosoft word
ne good advice now for the car??
Old Mar 7, 2008 | 10:38 PM
RED2000's Avatar
RED2000
3230 post > 4 post
Old Mar 7, 2008 | 10:56 PM
wdc 09's Avatar
wdc 09
ohhhh wowww how original, the good ol noob remark, wowww, come up with something new please, specially since ive been on here b4 just got a new name now thanks very much, ne ways again if u dont have info about where i could find a 8.8in rear end for my car for cheap or just a good place to get one from then y r u reading this and posting nonsense posts, thanks
Old Mar 8, 2008 | 02:49 AM
cobra232's Avatar
cobra232
ORIGINAL: wdc 09
i am always ready to help but i have to be able to read the post without taking 10 miuntes to get through txt style typing.
www.mpsautosalvage.com
try you local junkyards.
Rittenours auto salvage here in Ellsworth pa had an 8.8 from a 95 for i think about $350 but i know that rear was beat on.
and IMO and experience putting a detroit truetrac into your 7.5 is a much better choice than throwing in an 8.8 from a junkyard.
the junkyard 8.8 mave have damage that can easily go un-noticed and unless you find a 99+ GT rear or pre 99 cobra 8.8 they will have different ratios so you will either have to buy an xcal tuner to correct the speedo for the 8.8's different ration gears ($400) or get a set of 8.8 3.27's to put in the 8.8.
say you have to get gears so that another $200 added to the cost then $75 for an install kit then $200 minimum to install them and still have a used t-lok in it that may have worn out clutches $100 for a t-lok rebuild kit. now that uses 8.8 is costing $1000 to only have a heavierrear that is weaker than a detroit truetrac in the 7.5 that you could have paid $600 for the truetrac and install.
finding a low mileage good condition GT rear the same year as yours with the same ratio for cheap is near impossible.
this is my advise. just get the truetrac and forget about the 8.8.
if you think the 8.8 t-lok is stronger than this thing then your sorrily mistaken
Old Mar 8, 2008 | 08:13 AM
wdc 09's Avatar
wdc 09
Alright. Where could I get the Detroit Truetrac at? And is there anything else I would have to get for it, like new gears?
Old Mar 8, 2008 | 09:30 AM
thewrongguy's Avatar
thewrongguy
How much money are you looking to spend honestly? It's the internet so for all i know you could be HRH Prince Charles, but the txt typing makes me think 17yr old kid working part-time at pizza hut. Replacing a 7.5 with a 8.8 on a stock 3.8 isn't the best example of money well spent, a 7.5 will hold up to what 250-300 rwhp, are you going to go that far? Consider the t-loc cost, then gears (doesn't make sense to put in a posi without changing the gearing), installation kit, installation labour (get someone to do it), then getting your speedo recalibrated it all adds up pretty quick.
