good low end tq?
Old Mar 10, 2008 | 11:53 PM
1999mustang2000's Avatar
1999mustang2000
Default good low end tq?
what gives u some good low end torque,i dont wanna have to pull the engine or nething to get some. i was thinkin bout some pacesetter lt's? thnx
410's and t-loc
cai
exhaust
Old Mar 11, 2008 | 12:26 AM
l_shizzle_l's Avatar
l_shizzle_l
Default RE: good low end tq?
An intake spacer will add 6 or 7 lbs of torque and a couple ponies.
Old Mar 11, 2008 | 12:32 AM
1999mustang2000
i heard they dont work
Old Mar 11, 2008 | 03:15 AM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Eaton M112...
200ft/lbs @ 1.5k rpm
Old Mar 11, 2008 | 04:34 AM
jthorn9's Avatar
jthorn9
The Godfather
Intake spacers are different from throttle body spacers, they actually do add a little power unlike TB spacers.
With bolt ons your gains are going to be very minimal, and you'll spend a nice wad of money on mods that just will not have much yield, such as around $1000 just to get up to 180 rwhp with bolt ons. The best way would be to get a supercharger. They don't spool up until around 2000 RPMs, so that way under normal driving, you'll still get the same daily drivability with the potential for much more. They will not yield a lot low end wise, but they will yield power and torque where you need it, the middle/upper power band.
Old Mar 11, 2008 | 08:54 AM
The Yellow Pinto
Guest
Posts: n/a
anyone know if vapauto is still in business? i was thinking of ordering an intake spacer and a jmod from him...
Old Mar 11, 2008 | 10:58 AM
1999mustang2000
yea im pretty sure they r im goin to order a jmod and an intake spacer 2
Old Mar 11, 2008 | 11:01 AM
LilRoush's Avatar
LilRoush
V M P is still alive and kickin'.
As for long tubes, they'll kill your low end tq. Not sure where you got the idea they'll help.
Old Mar 11, 2008 | 07:58 PM
TheMichiganRA's Avatar
TheMichiganRA
So, can you explain why longtubes are good? Is it more for the uppper part of the power band?
Old Mar 11, 2008 | 08:13 PM
The Yellow Pinto
Guest
Posts: n/a
ORIGINAL: TheMichiganRA
thats correct. it kind of shifts your power band to make more power in the upper rpm range. usually, the gains are worth losing a lil bit on the low end..and if you go boost or nitrous, youll need to have the larger exhaust, starting with the headers, to really get rid of the burnt stuff quickly.
