quick quesiton
Old Mar 24, 2008 | 02:51 PM
amhsraptor's Avatar
amhsraptor
Default quick quesiton
is the 4.0L v6 in an explorer the same as the 4.0L v6 in a mustang? are they both ohc?
Old Mar 24, 2008 | 03:27 PM
amhsraptor's Avatar
amhsraptor
Default RE: quick quesiton
Does anyone know?
Old Mar 24, 2008 | 03:48 PM
jtowngt's Avatar
jtowngt
yes there is a difference the mustang has ohc
while explorer has ohv
[align=left] [/align]
Old Mar 24, 2008 | 04:54 PM
amhsraptor's Avatar
amhsraptor
Is that the only difference? I want to upgrade my ecu, and didn't know if I could use a 6cyl mustang tuner on my explorer or not.
Old Mar 24, 2008 | 06:19 PM
LilRoush's Avatar
LilRoush
Exploders come with two different types of 4.0L V6. One is SOHC, the other is OHV.
Why are you 'upgrading' to a different stock ECU?
Old Mar 24, 2008 | 08:06 PM
amhsraptor's Avatar
amhsraptor
I am interested in seeing how much power I could get with it, I believe it is OHV
Old Mar 24, 2008 | 08:41 PM
LilRoush's Avatar
LilRoush
If it's a newer Exploder, it will be OBDII - so you can use a handheld to tune it.
If it's old, it's still OBDI, and you won't be able to use your handheld on it. Has nothing to do with motor size/type... it has to do with ECU type.
Old Mar 24, 2008 | 10:05 PM
amhsraptor's Avatar
amhsraptor
It's a 2001 so I believe it is OBDII correct?
Old Mar 24, 2008 | 11:05 PM
LilRoush's Avatar
LilRoush
What type of tuner are you thinking of using? I would double check the part number for it as a Mustang tuner vs the part number for the Explorer of the same model.
Old Mar 25, 2008 | 12:04 AM
amhsraptor's Avatar
amhsraptor
I am going to an SCT dealer sometime this week to see if it will work or not. Everywhere I checked had tuners for mustangs and trucks but I couldn't find anything for explorers so i figured they might have a similar engine to the v6 Mustangs.
