newb question about hood scoops
Old Mar 25, 2008 | 09:11 PM
02stangridin's Avatar
02stangridin
Default newb question about hood scoops
like i said im a newbie so this is probably a dumb question but will the GT hood scoop fit a V6? just curious
Old Mar 25, 2008 | 09:57 PM
LilRoush's Avatar
LilRoush
Default RE: newb question about hood scoops
Yes.
Old Mar 26, 2008 | 10:09 AM
02stangridin
does it just bolt on or what?
Old Mar 26, 2008 | 10:19 AM
jthorn9's Avatar
jthorn9
The Godfather
From my research, you'll have to drill 4 small holes into the hood, and then it bolts on from there.
Old Mar 26, 2008 | 11:46 AM
stanglover1250's Avatar
stanglover1250
It depends what type of hood u got. 99-02 hoods u can but 03-04 u can't.
Old Mar 26, 2008 | 12:31 PM
Vtghost's Avatar
Vtghost
Also From reading Up On This There Are Two Types Of Hood Scoops, One Has Four Bolt Ons And The Other Has Six Guides and One Bolt If I Remember Right.....
But Yes You Will Have To Drill Some Holes But Make Sure Before You Drill The Holes You Put Tape On Your Hood So Your Paint Doesn't Crack! Also I Believe There Are Some Indents In The Inside Of Your Hood On Where You Should Drill...
Old Mar 26, 2008 | 12:50 PM
02stangridin
oh ok so there should be 4 indentions on the underside of the hood that indicate where to drill the holes? and what is this about the tape?
Old Mar 26, 2008 | 03:52 PM
stanglover1250
https://mustangforums.com/m_1997576/...tm.htm#1997576
Old Mar 26, 2008 | 08:41 PM
winner99's Avatar
winner99
Do they fit on the reverse V6 hood?
Old Mar 26, 2008 | 08:49 PM
stanglover1250
No.
