why is my car TICKING???
Old Apr 6, 2008 | 11:47 AM
alfredov6's Avatar
alfredov6
Default RE: why is my car TICKING???
my service engine soon light came on a couple days ago. n the ticking continues.... is it a header?
Old Apr 6, 2008 | 11:49 AM
mustangman02232's Avatar
mustangman02232
go to autozone and get a code ran for free and come back and tell us what it is... very well could be
Old Apr 6, 2008 | 04:05 PM
dbeatle's Avatar
dbeatle
oh down south duh that must be why i'm so hot forgot to turn my ac on, so if no ac on then whats the answer?
hes right have autozone read the code or any parts store but dont let them bull **** into buying things you might not need. we was good at that i used to run an autozone, yup we hired the best lol not
bet the code will be o2 sensor or egr valve
by the way nice car looks like one of mine minus the wing
Old Apr 6, 2008 | 04:28 PM
Cryptostorm's Avatar
Cryptostorm
i'd run the codes... but id look to make sure your not low on oil first...
Old Apr 6, 2008 | 05:03 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
ORIGINAL: MustangMike2001
Stop spreading that a/c drip bullcrap.
Wtf do you mean bullcrap?
That is the problem, the a/c does DRIP right on the mainfold and causes it to weakend and crack over time.....
So buy now its weak. No ac on in the cold (good job) its already worked its evil magic....
Old Apr 6, 2008 | 05:14 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
It could be a crap oil filter that doesn't have a properly functioning anti-drainback valve. If you're using fram oil filters, their valves suck and fail, so it may just be tapping from lack of lubrication after sitting, hence whyit goes away when the engine warms up, the oil's had a chance to move up an lubricate it.
Old Apr 6, 2008 | 06:48 PM
Cryptostorm
if it taps when he first starts the car, its unlikely that its any problem with the AC... aside from that, it would keep tapping rather then stopping...
my vote is to get a oil change, and a oil filter change
Old Apr 6, 2008 | 07:41 PM
skatealday's Avatar
skatealday
i had the same problem. i talked to my automotive instructor and he said it was mostlikely the rocker arms clicking against the pushrods. this is what i did and it worked excellently! carbon is a natural build up in all cars. to remove it this is what he suggusted. do an oilchange but when you go to put oil back in the car put transmittion fluid in. tranny fluid is a detergent so it will clean your rocker arms. once oilchange is completed start car and let run for about five minn at idol DONT get anyhigher than 2 rpm. after you let it run perform a natural oilchange. (look at the tranny fluid wooohhhh that was in your engine!!?)
Old Apr 6, 2008 | 10:32 PM
alfredov6's Avatar
alfredov6
i got a code from autozone a while back.... it said emissions control system faliure...or something like that... but they told me i needed a new gas cap the was all...n they cleared the code.... so idk...
but i guess its time for an oil change ill do that sometime next week
Old Apr 6, 2008 | 10:49 PM
MotoXFoo125SX's Avatar
MotoXFoo125SX
it could also be worn injectors. mine has 86k on it an it is ticking. sounds like its comin from around the intake manifold so im assuming its injectors.
