HELP - Skipping or Hesitation Problem
Old Mar 27, 2008 | 07:30 PM
GreggBig's Avatar
GreggBig
Default HELP - Skipping or Hesitation Problem
Help.
I am not sure if this is a V6 question or for all applications. Both my son and I have V6 convertible Mustangs. His is a 2001, mine a 2002. The problem started on his as a skipping or hesitation. Now mine has started. We have replaced the spark plugs and wires on both, but the problem continues. We have replaced the fuel filters, but the problem continues. It is most noticeable between 1200 and 1700 rpm, when under a slight load, up hill. But more noticeable with the air conditioner on. However, if you put you foot into it, the cars react perfectly. Both have cold air intakes. Could it be something as simple as a dirty air filter? Or any other suggestion?
Old Mar 27, 2008 | 08:40 PM
mws96's Avatar
mws96
Default RE: HELP - Skipping or Hesitation Problem
Automatics?
Old Mar 27, 2008 | 08:55 PM
GreggBig's Avatar
GreggBig
Yes, sorry I should have included that.
Old Mar 27, 2008 | 09:48 PM
mws96's Avatar
mws96
Have you checked the tranny fluid and sensors...?
Old Mar 27, 2008 | 10:04 PM
GreggBig's Avatar
GreggBig
No, But I will this weekend. Except for the obvious low fluid levels, what should I be looking for?
Old Mar 27, 2008 | 10:38 PM
july1992's Avatar
july1992
im having the exact problem on my 95 v6 stang.on low revs or going uphill it starts kicking.im going to autozone tommorow to see why my check engine light is on.but i believe its my coil pack.
Old Mar 27, 2008 | 11:04 PM
GreggBig's Avatar
GreggBig
Please post your findings. Both our Mustangs (mine and my son's) have not had the "Service Engine Soon" light come on.
Old Mar 27, 2008 | 11:10 PM
july1992's Avatar
july1992
yeah.tommorow ill post if its my coil pack.and i didnt read ur entire first msg.butialsodo the same thing and when i put my foot on the pedal itstops kicking.just saying because it seems were having the exact same problem.
Old Mar 28, 2008 | 01:12 AM
l_shizzle_l's Avatar
l_shizzle_l
Your MAF(Mas Air Flow) sensor could need to be cleaned, it will behave like this before it does set off a CEL(Check Engine Light), at least mine did. Also make sure there is nothing stuck on your air filter or in the intake, believe it or nota large maple leaf somehow wraped arround my air filterone day and caused symptoms like this.
BTW your stang looks nice, post some pics.
Old Mar 28, 2008 | 01:33 AM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
I think this is a common problem with Mustangs. My 95 did the same thing, at the same RPM range with the A/C running. I had a cobra guy say his did the same thing under the same circumstances. I think its just a flaw from Ford.
Matthew
