do i need anything else???
Old Mar 30, 2008 | 09:20 PM
03stang0802's Avatar
03stang0802
Default do i need anything else???
when buying gears or underdrive pulleys, do i need to purchase anything else? to install or is everything set to go when my order arrives? or do i need to change anything along with gears or pulleys..
Old Mar 30, 2008 | 10:31 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: do i need anything else???
You'll need a belt for the pulleys if it didn't come with one. And you'll need a programmer for the gears. If you didn't order it, you should order some type of lsd for the rear too, the cheapest I believe is a ford t-lok.
