Force Pro Size?
Old Apr 5, 2008 | 09:37 PM
Russell12988's Avatar
Russell12988
Default Force Pro Size?
What size inlet and outlet will fit for my 01'? about to buy them off summit but not exactly sure which ones i need.
Old Apr 5, 2008 | 09:39 PM
MustangMike2001's Avatar
MustangMike2001
Default RE: Force Pro Size?
2.25
Old Apr 6, 2008 | 12:08 AM
Unforgivine's Avatar
Unforgivine
i plan on doing the same
Old Apr 6, 2008 | 12:28 AM
Russell12988
Does it really matter what the position is of the inlet or outlet? im goin to a shop to get them to fab a true dual setup for me
Old Apr 6, 2008 | 12:40 AM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
yes it matters. If you have the wrong inlet and outlet possition the mufflers will not fit. I have Flowmaster 40 with a center inlet and because of them being centered I couldnt use them on my car. Make sure to get the right in/outlet ports or they will be useless.
Matthew
Old Apr 6, 2008 | 01:08 AM
MustangMike2001
You'll need offset inlet and offset outlet
Old Apr 6, 2008 | 08:41 AM
The Yellow Pinto
Guest
Posts: n/a
well, if you are a 1.4 of an inch off, they can use an apadter to make it fit. but id buy a 2.25 inch in/out of you are going with the same size pipe (for stockish), or go 2.5 if you are planning on power adders.
Old Apr 6, 2008 | 03:24 PM
v6stang07's Avatar
v6stang07
unless u are looking at lots of power i would stick with 2.25.thats what i have now and love it
Old Apr 9, 2008 | 02:15 PM
robinson209's Avatar
robinson209
ORIGINAL: MustangMike2001
What do you mean by that?
Old Apr 9, 2008 | 02:20 PM
The Yellow Pinto
Guest
Posts: n/a
looks like this:
I ---
--- I
ALL BOW DOWN TO MY DRAWING SKILLS!
