The problems continue...
Old Apr 6, 2008 | 09:00 PM
Deepenough's Avatar
Deepenough
Default The problems continue...
OKay so after the windsar intake install ive had a few problems, most are now sorted out i think, including the overheating and no heat blowing. Turns out that it was my thermostat. Now the other problem... when i drive the car at a certain point maybe 3/8 of the way down when im on the gas pedal a louddddd squeal happens, it sounds like air is being let out somewhere and then as soon as i let go of the gas pedal from 3/8 the pitch of the squal goes the other way, sounds like its sucking something back in... its really wierd.It only does this at that point... when i gun it oranythingg else but around 3/8 the sound isnt there.Since i ported the lower and put the windstar on... there is a chance that i ported to far out somewhere and one of the gaskets may not be sealing properly especially since the windstar has the figure rubber gaskets rather than a flat gasket like the stock upper has... i dunno.. any suggestions?
Old Apr 6, 2008 | 10:14 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: The problems continue...
Use a tube of gasket sealer and re-install the intake, just in case there is a small leak.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
