EGR valve problem
Old Apr 19, 2005 | 05:19 AM
roushis4lovers's Avatar
roushis4lovers
Default EGR valve problem
repalced my EGR valve which went out at 23000 miles, what would cause that??
Old Apr 19, 2005 | 07:59 AM
97Stallion's Avatar
97Stallion
Default RE: EGR valve problem
hmm, are you sure it was your EGR valve that was bad? Those usually go bad because of a build up of carbon in them. That's the only thing I can thing of, maybe you just had one of those that were poorly built ans slipped though. it happens.
Old Apr 20, 2005 | 09:09 AM
wiseguy's Avatar
wiseguy
Did the diaphragm have a hole in it? Pull a vacuum on the valve and see if it holds it. If the valve won't move when vacuum is applied, then the diaphragm is leaking or the valve stem is seized in the body.
TfcCDR
Sep 14, 2015 12:08 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
zanemoseley
Sep 6, 2015 12:58 PM
