no the cobra and GT rear ends are not similar well the termi arent at least the termis are IRS and unless your building an autoX car i would stick with the 8.8 get one off a junked GT and build it
tranny fit my car
or should i just get the sts
and the 8.8 rear end gears and lock
1- yes. but you dont have the power to use that 6th gear to its potential, nor maintain speed uphill on highways. not worth the money to swap it in.
2- STS? english please.
3- NO. they are called 8.8 and 7.5 for a reason- the ring gear size. wont fit. you could swap in the whole rearend(housing, axles, differential), but you would be better off with a locker and gears for you 7.5 at this point.
as for IRS, it would bolt in. but 900 bucks could be best spend elsewhere at this point.
