Rotor Issue?
Old May 6, 2008 | 01:19 PM
kahaj's Avatar
kahaj
Default Rotor Issue?
When I have to stop fairly fast, I've noticed that there is a definite vibration. I'm thinking that the rotors are maybe warped. How do I check to know for sure and is there anything else that this could likely be?
Old May 6, 2008 | 01:48 PM
1367mustang's Avatar
1367mustang
Default RE: Rotor Issue?
If you have ABS brakes it may be that ???
Brian
Old May 6, 2008 | 01:56 PM
The Yellow Pinto
Guest
Posts: n/a
take off your wheels and look at em. if you warped your rotors, you propbably need new pads as well. hopefully, you can get em machined...but if not, use this opportunity to upgrade. good luck!
Old May 6, 2008 | 07:29 PM
kahaj's Avatar
kahaj
I assume that it will be easily told if the rotor is warped?
Old May 6, 2008 | 08:32 PM
jwog666's Avatar
jwog666
if the steering wheel shakes and the pedal pulsates when using the brakes your front rotors are warped for sure.
Old May 6, 2008 | 10:39 PM
kahaj's Avatar
kahaj
Well, hopefully I can afford to go ahead and upgrade since they need replaced anyway.
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Sep 30, 2015 10:13 AM
