HELP!!!!!!!
Old May 6, 2008 | 07:04 PM
96GT34's Avatar
96GT34
Default HELP!!!!!!!
I got a 94 and the rear brakes are leaking, well its coming from the rubber hose which goes into the junction block. I can't figure out how or even if the junction block can be removed from the rear axel. Any help would be much appriciated
[align=left] [/align]
Old May 6, 2008 | 07:36 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: HELP!!!!!!!
it's bolted to the diff, I think it's a 10mm. It's all prtty easy to remove, just be careful when bleeding them, there will be a LOT of air in the system and you want to make sure you get it all out.
Old May 6, 2008 | 07:54 PM
96GT34's Avatar
96GT34
Thanks, yeah i started screwing with it and finally figured it out, sad that i couldn't even figure that out how to take out one bolt but thanks for your help
