trouble code???
Old Jun 6, 2008 | 01:13 PM
1999mustang2000's Avatar
1999mustang2000
Default trouble code???
PO430
it was a catalyst code
im not really sure wat it means this is the first time my cars threw a code
Old Jun 6, 2008 | 01:25 PM
tweak04's Avatar
tweak04
Default RE: trouble code???
A code P0430 may mean that one or more of the following has happened:
The catalytic converter is no longer functioning properly
An oxygen sensor is not reading (functioning) properly
or there isan exhaust leak
Thefirst thingid do is reset the code and see if it comes back.
Then inspect for exhaust leaks.
Next step is to measure the voltage at the oxygen sensors on Bank 2 If the voltage varies (e.g. 100mV to 600mV) then it's time to replace the catalytic converter. In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
Old Jun 6, 2008 | 02:04 PM
The Yellow Pinto
Guest
Posts: n/a
that code means faulty 02 sesnor 99 times out of 100. unfortunately, ive had that code come up on a lot of cars. the summertime heat seems to make em crap out faster.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
CS2007
Jun 25, 2019 09:45 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
