porting
Old Jun 8, 2008 | 08:42 PM
wdc 09's Avatar
wdc 09
Default porting
i plan on porting my stock headers but i need to know how much i can widen the pipe before it gets to weak. im not doing this myself, i just need the info for the guy who is doing it....
thnaks
Old Jun 8, 2008 | 09:05 PM
LilRoush's Avatar
LilRoush
Default RE: porting
Headers? As in exhaust manifolds?
Don't port those. If someone told you he was going to do that, don't trust him with your car.
Old Jun 8, 2008 | 09:11 PM
wdc 09's Avatar
wdc 09
Default porting
yeah, exhaust manifolds.
oh i read somewhere where you could do that. so i was gona have my uncle who has a machine shop do it.
but why cant you do it?
Old Jun 8, 2008 | 09:31 PM
LilRoush's Avatar
LilRoush
Default RE: porting
No need to. Stock exhaust manifolds are good to over 350 hp worth of air. If an upgrade is needed, purchasing an aftermarket set is much easier and cheaper.
For the most part, porting is reserved for heads and intakes.
Old Jun 9, 2008 | 07:20 AM
wdc 09's Avatar
wdc 09
Default RE: porting
alright. thanks for that info, would of been bad if i went and did it..
so you can port upper and lower intake manifolds?
Old Jun 9, 2008 | 11:44 AM
LilRoush's Avatar
LilRoush
Default RE: porting
Yes, I'd suggest at least gasket port matching, and match the TB to the upper as well.
But if you want to spent extra, cutting open the upper intake and grounding it out the full length of the runners will scoop up even more hp for you. The hard part is welding it back together. The lower you can fully port without cutting it due to the short length of the runners.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
TfcCDR
Sep 14, 2015 12:08 PM
