Which Engine?
Old Apr 30, 2005 | 12:11 AM
l_o_t_s_r's Avatar
l_o_t_s_r
Default Which Engine?
which engine would you recomend out of the 1980=1985 2.3L Carburated, and the 2.3L out of a 1987 (Fuel Injected), I'm also considering dropping a 302 in one of the two mustangs I'm getting any help would be greatly appreciated, and whats better for mods and hp Caburated or Fuel Injected 302? thnx
Old Apr 30, 2005 | 12:49 AM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: Which Engine?
I like carberated because you can disconnect all the sensors and run without any computer with no problems. You can also adjust your air fuel mixture real easy with a carberatur without any kind of tuner. I would stick with a 2.3 unless your going to swap out your hole drive line.
Also a trick I found to pass emissions with hollowed out cats on a carberated engine is you lean you engine out to where it still runs smooth but still pretty lean and you'll pass emissions no problem.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
