Timing?
Old Apr 30, 2005 | 01:47 AM
metalfloyd's Avatar
metalfloyd
Default Timing?
I was wondering whether I should adjust the timing on my car. I have a Diablo sport reprogrammer and I was wondering what the advantages of adjusting it would be if there is any.
Old Apr 30, 2005 | 02:17 AM
2kConvMustang's Avatar
2kConvMustang
Default RE: Timing?
I think if you advance it alitte you'll get some more HP but, in turn you gotta get higher octane gas. If you retard it that would be more useful for NOS or power adders, i think but someone correct me if im wrong tho.
thunderstang00's Avatar
thunderstang00
Default RE: Timing?
i dont know anything on that, but is was wondering how the flash tuner is? also on it can you change gas settings, (such as changing it from 93 to 87 or whatever)
Old Apr 30, 2005 | 05:14 AM
97Stallion's Avatar
97Stallion
Default RE: Timing?
Actually those reprogrammers aren't all that great. You're VERY limited on what you can change. The only real way to do anything worth while is to tap into your EEC with the SCT software. With that you can add timing, change your shift points, anything and everything you can think of you can do with it. Finally to answer your question, you don't wanna mess with your timing. You should always keep it straight up. Once you get a knowledgeable tuner to work with you, let him mess with the timing. Your timing is a fragile thing. Going to extreme could result in disater.
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
