catback
Old Jun 22, 2008 | 08:31 AM
troy81's Avatar
troy81
Default catback
imma get 2 force pro mufflers but i was wondering what company makes a good cat back dual system for our cars? H pipe preferred. im reasearching right now so any suggestions welcome
Old Jun 22, 2008 | 09:22 AM
LilRoush's Avatar
LilRoush
Default RE: catback
A cat back will include mufflers - so you'd be losing money from one or the other. The H pipe is the mid pipe (or catted part).
If you are looking for a good mid pipe, go with Mac.
Old Jun 22, 2008 | 07:28 PM
troy81's Avatar
troy81
Default RE: catback
ok so mac makes a good H pipe. what about over axels? does anyone sell the over axels seperate? im im doing either catless or only 2 cats,im just going to hollow out my stock cats
Old Jun 22, 2008 | 07:31 PM
Omnislash27's Avatar
Omnislash27
Default RE: catback
I just bought the flowmaster 40's catback system, but had the guys at the shop make an H-pipe and put that on instead of the Y-pipe. Sounds great and no problems whatsoever, but also depends on how much youre willing to spend.
Old Jun 22, 2008 | 08:48 PM
The Yellow Pinto
Guest
Posts: n/a
Default RE: catback
dont buy a premade catback system at all, especially not for our cars. there are some great premade ones for the gts, and for some nicer imports (did I just say the I word? :P)...but nah, the premade ones will run you more than having a local shop custom bend your pipes for you, your choice of muffler. add the hpipe if you like. i run the force pros and fabbed 2.5 inch duals, and LOVE them.
eh, just my sugesstion. i just took an ambien and it is making me loopy. o think its sleep y time for adam.
Old Jun 22, 2008 | 08:56 PM
Omnislash27
Default RE: catback
I agree with you on that one, but i went to a shop and they didnt bend it enough so it kept on hitting the axle...eventually making the pipe smaller. After that i just went on Ebay, found some pre-bent pipes and a couple of flowmaster 40 mufflers and had the guy at the shop throw it all together. Worked out very well actually, but do as you see fit.
Old Jun 22, 2008 | 08:57 PM
HornyHornyHippo's Avatar
HornyHornyHippo
Default RE: catback
I agree, you might not be able to predict the sound as accuratly as you would if you bought a brand name, but its cheaper and adds the "cool" factor. I have flowmaster 40s with stock mid pipe and headers and i like it alot. Only breathing mods i have are the catback and the cold air intake and i love it.
ORIGINAL: Omnislash27
If the shop didnt bend the pipes right, then thats kinda the shops fault and i wouldnt make the assumption that every shop is gunna give you an unsuitable custom exhaust. I would have demanded satisfaction and gotten them to redo it.
Old Jun 22, 2008 | 09:03 PM
The Yellow Pinto
Guest
Posts: n/a
Default RE: catback
yeah, omni, ive ran into that before. it is hard to gauge who is a good pipe guy buy the way the shop looks. ive gone into a local midas once and got a beautifully bent, compression bend header back exhaust installed, beautiful welds, no leaks, tucked up real tight, no cabin vibrations....very happy.
then on another car, per recommendation of a friend of mine, i went to the "exhaust master" in my town for them to install a single exit on my old four banger...hack and chop job, clamped the majority of it together, hung low, sounded like crap...and used a conbination of 2.25..then to 2.5...then back down to 2.0 inch exhaust pipes on the car, having difficulties with getting it over the axles and what not. terrible.
Old Jun 23, 2008 | 04:21 PM
troy81's Avatar
troy81
Default RE: catback
are our cats bolted or welded in? i want to hollow em out soit seems like theres cats there but i dont want any. from there i think ill have the shop fab an H pipe andthe over axels and ill have em throw 2 force pros on it, i finally heard em on a catlessGMC jimmy with only one and i really like the sound. how much should i look for in a price for all that?
Old Jun 24, 2008 | 08:35 PM
troy81's Avatar
troy81
Default RE: catback
Spiral534
Oct 6, 2015 04:31 PM
firecoyote
Sep 27, 2015 02:37 PM
mryeah256
Aug 28, 2015 02:01 PM
mryeah256
Aug 20, 2015 10:00 AM
