Drivers side window stuck!
Old Jun 26, 2008 | 11:30 PM
locky's Avatar
locky
Default Drivers side window stuck!
Well like the title says my drivers side window is down and wont roll up, There arent any noises when I try to roll it up but if I try to roll it down there is a clicking noise understeering wheel.
Any advice on what to do would be greatly appreciated.
Old Jun 27, 2008 | 12:12 AM
JKs95stang's Avatar
JKs95stang
Default RE: Drivers side window stuck!
ORIGINAL: locky
What year is your car? It's really tough to say with your description, but I would be willing to bet the motor is stuck. Try smacking the lower part of the door panel, if that works, your bushings in the window motor are getting worn out. It's a common problem with fords, there window motors suck, luckily, you can rebuild them CHEAP!! I would also check the fuses just to make sure. More information would definitely help. GL
Old Jun 27, 2008 | 12:32 AM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Take off your door panel
Locate window motor
Say "vcs_ssstang" 3 times and hit it ....
Roll it up
Old Jun 27, 2008 | 02:17 AM
JKs95stang's Avatar
JKs95stang
ORIGINAL: VCS_SSSTANG
Locate window motor
Roll it up
The GENIE EFFECT, works EVERY TIME!!
Old Jun 27, 2008 | 06:39 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
I didn't take off my door panel and it still worked! LOL
But yes, just whack the **** out of the door panel on the inside near the motor, while pushing the up button and it will go back up.
Old Jun 27, 2008 | 08:28 AM
locky's Avatar
locky
Thanks for the help. Sorry for not being more descriptive, its a manual 2000 v6 mustang
Old Jun 27, 2008 | 01:52 PM
locky's Avatar
locky
Thanks for the hlep guys, I hit it a few times and it rolled right up, now should I use it like normal? Or is the motor almost dead?
Old Jun 27, 2008 | 03:03 PM
JKs95stang's Avatar
JKs95stang
ORIGINAL: locky
It's probably not almost dead, but eventually you will have to either rebuild the motor, or purchase a new one. I wouldn't go to ford and get one, they are EXPENSIVE!! You can find them on Ebay for like 60 70 bucks. It could never happen again, but at least you know how to fix it now!!
Ford Window Motors FTL!! [:'(]
Old Jun 27, 2008 | 07:32 PM
RyansQuick6
Reverse Gear Member
No it's fine, mine did it once 8 months ago and it hasn't happened since
Old Jun 28, 2008 | 12:31 AM
sinniebunnie's Avatar
sinniebunnie
been there.. done that.. basically your wiring is messed up.. use a battery to power up the windows for now..
