v6 problem
Old Jul 18, 2008 | 05:44 AM
aaronrmrz's Avatar
aaronrmrz
Default v6 problem
my lil brother was driving in 1 , 2 and drive in an automatic car, the next day the car started vibratinMy lil brother was driving in 1 , 2 and drive in an automatic car, the next day the carand the car struggles a lilttle to climb speed and it also pulls when accelerating, i changed wires sparkplugs, cleaned injectors,replaced fuel filter,checked cylinder compression, fuel line pressure, changed oil, transmission oil and filter, and intake filter, the coil pack is also good, any ideas whats wrong with it?? 2001 mustang 3.8 started vibrating andthe car struggles to climb speed and it also pulls when accelerating, i changed wires sparkplugs, cleaned injectors,replaced fuel filter,checked cylinder compression, fuel line pressure, changed oil, transmission oil and filter, and intake filter, the coil pack is also good, any ideas whats wrong with it?? 2001 mustang 3.8
Old Jul 18, 2008 | 07:58 AM
my94pony's Avatar
my94pony
Default RE: v6 problem
i dont know but you repeated youself alot
Old Jul 18, 2008 | 09:34 AM
RPM3DINC's Avatar
RPM3DINC
In town I drive my 06 Stang (Auto) in 1st, 2nd, 3rd, then drive (with Overdrive on), I have had no problems at all... and I still get 21MPG doing that... It sounds like you have checked everything over good, so not sure what else to suggest... Perhaps take it to a Ford Dealer, let them drive it, or you drive it and see if it will do what you are describing with a Tech in the car with you... then go from there...
Old Jul 18, 2008 | 09:56 AM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
ORIGINAL: my94pony
Yeah, I had to read it 3 times, which felt like 6 times just to understand it. Sorry dont know.
Matthew
Old Jul 18, 2008 | 01:15 PM
cwyates4's Avatar
cwyates4
I dont think driving it in 1, 2, d, and Od would have hurt it...unless he over revved it...
Old Jul 18, 2008 | 02:27 PM
v6stang07's Avatar
v6stang07
it could b the fuel pump. i kno u checked the line pressure but it may be slacking as the car heats up or some other variable. i would get someone to hook up a diagnostic computer to it and drive it around then see if u can figure out what it is
Old Jul 19, 2008 | 12:02 AM
mustangman02232's Avatar
mustangman02232
1-2-D wont hurt i did it on and off for 50k on mine and the only casualty of it was the rear end
are you sure the coil is good? but i couldnt really understand the post[&:]
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
