A/C question
Old Jul 23, 2008 | 11:17 PM
Phantoms's Avatar
Phantoms
Default A/C question
Ok on Monday night I had the a/c charged in my car. When I turned it on max a/c it blew out the dash vents. Did that all the way home. Tuesday I got up to go to work and turned it on max a/c again. Now it will only blow out the defroster and floor. No matter what I set it to. What could be the cause of that and how do I fix it?
Old Jul 24, 2008 | 08:38 AM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: A/C question
There is a set of vacume hoses in the corner of your engine bay, if one comes unpluged from there, or anywhere else in the system it will cause your problem. Since they come off easy, look here for your problem, granted, I have a 5.0, but V6s are pretty much in the same spot.
[IMG]local://upfiles/22329/E22384B7C3DB44C88AB024AF2CC64495.jpg[/IMG]
Old Jul 24, 2008 | 07:09 PM
Phantoms's Avatar
Phantoms
Thanks jthorn. I will check that out and see if that's my problem. Haynes manual doesn't help with that particular problem.
Old Jul 27, 2008 | 09:31 AM
Phantoms's Avatar
Phantoms
jthorn - I do see where a hose is loose on the side of the car. I can't tell if it broken off the rubber boot or if it popped out of the boot. Can point me in the right direction to fix it?
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
