EGR problem, P0401
Old Aug 6, 2008 | 12:44 AM
l_shizzle_l's Avatar
l_shizzle_l
Default EGR problem, P0401
So after i was sputtering for a day or so this code popped up. The sputtering only happens at part throttle and it's more noticable in the lower gears. The passanger side of the engine bay is also hotter than the driver side. Any ideas yall?
And i have longtube headders.
Old Aug 6, 2008 | 08:23 AM
The Yellow Pinto
Guest
Posts: n/a
Default RE: EGR problem, P0401
if its the egr, you could always delete it with the vmp kit, and get it turned off with a tuner...
Old Aug 6, 2008 | 01:47 PM
l_shizzle_l
Don't want to delete it, i like my good gas mileage.
Old Aug 6, 2008 | 02:26 PM
The Yellow Pinto
Guest
Posts: n/a
my mileage isnt too bad..but then again, im not making the same power as you.
Old Aug 7, 2008 | 08:48 PM
white v6's Avatar
white v6
I have a 73 millimeter MAF andMac 1 5/8inlong tube headers and 2.5inMac H-pipe with catsand Mac 2.5in Gt catback on my 3.8. MyEGR pipe is a half inch to longso it's plugged. I now have the following codes. p1407 no EGR flow (duhh) p1000 system dignostic failure?
[sm=dontgetit.gif]
Old Aug 7, 2008 | 09:22 PM
white v6's Avatar
white v6
It missis at idle hesitats and has no power so I parked it for repairs. Do ether of you know anything about the p1000 code if you can help me thanks if not thanks anyway.
Old Aug 20, 2008 | 09:44 PM
pianomanbj's Avatar
pianomanbj
On my stang, it was running rough at idle (engine changing rpms, missing, etc). It threw a p1000 code... Basically the computer thought the egr valve needed to be opened at low throttle (not half or WOT)...So the engine was getting exhaust air at idle, wonder if that could be the case with you....just a thought
Old Aug 20, 2008 | 11:10 PM
jwog666's Avatar
jwog666
p1000 code is for obd2 diagnostics not completed, not for egr. this code comes up when the emissions tests for all the systems are not completed(means nothing). p0401 is egr insufficient flow detected, first check the 2 rubber hoses the come from the tube that connects to the erg valve to make sure they are connected. if they are than 99.9% of the time the dpfe sensor is to blame. the dpfe sensor is the sensor that the 2 rubber hoses that come off the egr tube connect to. to check that, get a vacuum pump and pull a vacuum on the valve with the engine running, if it stalls its for sure the dpfe sensor.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
