Check Engine Light WON'T come on
Old Aug 14, 2008 | 08:44 AM
NightwingIII's Avatar
NightwingIII
Default Check Engine Light WON'T come on
Your reading this right. I got the Service Engine soon Light on. Scanned the ECU.
Got the P4101 code. After reading some forums I changed the DPFE Sensor. It was a 50-50 shot at the problem. Versus the EGV Valve.
Anyways... started the car again and reset the codes.
Now for some reason the Sevice engine soon light will not come on during start up. I know it did before when you turned on the car and then it turned itself off after the other lights did.
A bit hard to explain sorry. I hope you guys can help.
Thanks in advance,
Old Aug 14, 2008 | 09:33 AM
my94pony's Avatar
my94pony
i understand what ur saying but i dont know why just that one wont come up
Old Aug 14, 2008 | 10:02 AM
NightwingIII
Sorry... What I meant to say was the others are coming on and off normally but the Check engine soon isn't doing the same like it did before.
Old Aug 14, 2008 | 11:45 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
pull the cluster and check the bulb, iot'll take all of 10 minutes.
Old Aug 14, 2008 | 12:37 PM
NightwingIII
I thought that. But the light work just prior to me clearing the code so I find that unlikely.
I'm gonna try reset the ECU by removing the batt cables for a bit and see if that works.
Old Aug 14, 2008 | 12:59 PM
RyansQuick6
Reverse Gear Member
Why not try the easiest steps first?
Old Aug 14, 2008 | 10:05 PM
mustangman02232's Avatar
mustangman02232
Angry
check the bulb,
the low fuel light burned out on my toyota..... that wasnt a good night
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
