get LOWWWWWWW
Old Aug 16, 2008 | 03:35 PM
echarlemagne's Avatar
echarlemagne
Default get LOWWWWWWW
according to Lil Roush and many others, my car needs 2 be lowered... well after 2 minutes of thought i finally made the decision 2 do so, what kind of info do i need 2 know as far as lowering is concerned? ideal inches?? i have "18" inch wheels and my tires are 275 40 18s (when i use measuring tape they are 19) price??? etc... help me out... here is a photo to help u eye ball it...
Last edited by echarlemagne; Aug 16, 2008 at 03:36 PM. Reason: HTML link didnt work
Old Aug 16, 2008 | 03:45 PM
tunnerdad's Avatar
tunnerdad
id say an inch in a half to two inches
hookedonkronik's Avatar
hookedonkronik
hey there,
Typically 2 inches is the most any one ever drops. When you go two inches, you are recommended however to also get new caster/camber plates to avoid unnecessary pressure on your tires from the drop.
However, i've read that dropping 1.5 inches does NOT require caster/camber plates so this is what alot of people do. The 1.5 drop is low and noticeable so I dont think you'd be disappointed.
It's recommended while swapping the springs to also change struts/shocks if they seem to be old (maybe over 100k km).
Good luck, your car will look sweetER once dropped (all stangs do)
Old Aug 16, 2008 | 05:21 PM
moontang's Avatar
moontang
buy mine? haha yes anything lower than 1.5 inches it is recommended that you get C/C plates and i can say anything around 1 inch is noticible on the car try to stick with well known brands i.e. eibach FRPP roush things like that suspension is one thing i wouldnt recomend going cheap on its preaty important
Old Aug 16, 2008 | 06:14 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
oh crap there's a black guy trying to steal your car! lol j/j
I'd recommend about 1.5"
Old Aug 16, 2008 | 07:10 PM
baddog671's Avatar
baddog671
I think your stance looks good already, you New Edges sit alittle lower then the SN95's I think. 1.5" should make it look pretty sweet.
I'm lowering mine around 1.5" with eibach, beefed up sway bars, and new polytype bushings.
Old Aug 17, 2008 | 12:02 AM
Zach333's Avatar
Zach333
yyuppp 1.5 inches sounds correct
your such a baller i wanna be you
Old Aug 17, 2008 | 12:09 AM
ESG-642T's Avatar
ESG-642T
Buyer Beware
I didn't find that funny , Got a problem with black people?
Old Aug 17, 2008 | 01:55 AM
MustangMike2001's Avatar
MustangMike2001
LOL! and I thought what I was thinking was bad..
Yeah 1.5 is perfect, I wouldn't go any lower than that. You will still need camber bolts for the alignment.
Old Aug 17, 2008 | 01:56 AM
echarlemagne
Not all black people drive Dodge Chargers or Chevy Impalas sittin on 22 inch rims u know.... i didnt appreciate that racist a$$ comment of urs.... but w/e no point in me cussin u out over the net like i really want to... if only u were to say that in my presence.... ANYWAYS...some friend of mine told me that the down side (pun not intended) of lowering ur car is that people who do alignments or balancing charge extra for those services... that true??
