lowering car
Old Aug 24, 2008 | 03:27 PM
Richbrad08's Avatar
Richbrad08
Default lowering car
i look in the hot to thread it had someone lowering by cutting the spring....aint that unsafe?
Old Aug 24, 2008 | 03:28 PM
Richbrad08's Avatar
Richbrad08
how to's***
Old Aug 24, 2008 | 04:09 PM
baddog671's Avatar
baddog671
Damn, that was a confusing sentence! Spell properly!
If you do it correctly, it isn't dangerous...
Old Aug 24, 2008 | 04:13 PM
reaper2022's Avatar
reaper2022
if you do it correctly, everything works out just fine. It's when you half-a** it that things get dangerous.
Make sure you get an alignment after lowering, too
Old Aug 24, 2008 | 05:23 PM
Xemeth's Avatar
Xemeth
As long as you use a saw or die cutter or to cut them, it doesn't effect them. Stock springs aren't progressive rate, so the spring rate isn't effected from cutting a coil off. Just don't use a torch or head to cut them.
Old Aug 24, 2008 | 06:01 PM
Richbrad08's Avatar
Richbrad08
ok thks......ya this comp sucks sometimes when i type bc the mouse pad will go somewhere and get click somewhere on the screen and start my sentence there so sometimes it mess up
inyadreems
Aug 21, 2015 09:10 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
