windstar done
Old Aug 27, 2008 | 11:39 AM
richmustang1880's Avatar
richmustang1880
Default windstar done
well its done for the most part just gotta work out the kinks here are some pics
Attached Thumbnails windstar done-dsc03362.jpg   windstar done-dsc03354.jpg   windstar done-dsc03361.jpg
Old Aug 27, 2008 | 12:14 PM
Black04's Avatar
Black04
Looks great, do you notice much improvement on performance?
Old Aug 27, 2008 | 12:57 PM
richmustang1880
i can notice the difference in the low-mid end not really anything in the top but theres an old road and from the stop sign to the same mailbox i gained a 3-4 mph. this is with 5 runs on the old intake but just one with the new and all the kinks arent worked out yet so as soon as its 100% ill run it again.
Old Aug 27, 2008 | 02:04 PM
stangant's Avatar
stangant
looks good. also have u noticed how the sound changes in higher rpms. i know after i installed mine it got deeper.
Old Aug 27, 2008 | 03:21 PM
v6stang07's Avatar
v6stang07
is this with vap's kit or is this your own conversion?
Old Aug 27, 2008 | 06:15 PM
3.8_Special's Avatar
3.8_Special
Possable to stick a vortec on the end of the throttle body there? or does the turbine run perpendicular to the belt drive?
Old Aug 27, 2008 | 08:23 PM
psyviperx's Avatar
psyviperx
thats the VAP kit.
yes it is possible to s/c with the windstar and it works rather well. you needcustom piping from the tb to the s/c. if giung s/c you can even keep the stock airbox because the s/c kit will pipe to it.
Old Aug 28, 2008 | 02:32 PM
The Yellow Pinto
Guest
Posts: n/a
looks really good. it seems like ive seen some other windstar intakes that use a really cheap looking intake ducting to the manifold. yours looks much better.
is the intake pipe supported by anything underneath, or is it pretty firm with just the rubber pieces and hose clamps?
Old Aug 28, 2008 | 05:48 PM
richmustang1880
its really firm with just the rubber and hose clamps
Old Aug 28, 2008 | 06:25 PM
Vovovovan's Avatar
Vovovovan
is a windstar intake a direct bolt on for a mustang?
