humming sound coming for engine
Aug 29, 2008 | 04:03 PM
I have been hearing a humming sound coming from my engine. I have tracked down the sound and it is coming from my power stiring pump. Can it be caused my a leck or is it going out or somthing?
Aug 29, 2008 | 04:44 PM
When do you hear it? when it's cold? hot? when you turn the wheel???
Aug 29, 2008 | 05:14 PM
if the resevoir is full you dont have a leak. flush the fluid out with new stuff. sometimes that fixes it. sometimes you have to replace the pump.
Aug 29, 2008 | 05:31 PM
Could be your gaskets going out. Ford in notorious for their very loud power stearing pumps. Is it a recent noice? Or has it been there for a while.
Matthew
Aug 29, 2008 | 10:04 PM
You can hear it soon as u start the car up and gets louder when u turn the wheel.
Aug 29, 2008 | 10:15 PM
check the fluid, if its low fill it up with ATF, DO NOT OVERFILL IT,
all my fords have had loud PS pumps
Aug 30, 2008 | 12:23 PM
it is full but i think i over filled it. is there a way to drain all of it out and put new ps fluid in it?
Aug 30, 2008 | 03:18 PM
i went out and bought stop leak stuff for it.
Aug 30, 2008 | 07:57 PM
Stop leak can damage the pump by damaging the internal seals
Aug 31, 2008 | 08:35 AM
the power-steering pump on mine sounds like it came of a lorry.....it gets louder still when you turn the wheel. its always been the same.
