Detailed Engine...
Old Sep 3, 2008 | 07:19 PM
cynic2005's Avatar
cynic2005
Smile Detailed Engine...
After leaving the army I bought a 96 mustang with a V6 3.8L. Since, working on cars has become a personal hobby. Here's my engine after three months of work. I had the longblock rebuilt by a machine shop, and I personally did all the custom detailing. It has a cold air intake system, a bigger throttle body, shorty headers, dual exhausts, and the ECU has been tuned with a SCT flash tuning device. I've also upgraded the suspension with high performance struts and shocks, and installed a kenwood dvd/cd entertainment system with infinity speakers. Let me know what you V6ers think of it so far.
Old Sep 3, 2008 | 07:26 PM
MustangMike2001's Avatar
MustangMike2001
Looks cleannn man, very nice.
Old Sep 3, 2008 | 08:00 PM
3.8_Special's Avatar
3.8_Special
Very clean, very nice.
Im interested in seeing how you have your DVD player set up.
Old Sep 3, 2008 | 08:06 PM
Vovovovan's Avatar
Vovovovan
wow, just wow. i spent a can of engine degreaser 3 teeth brushes and 5 hours of life, and it's still not that clean.
Old Sep 3, 2008 | 08:37 PM
cynic2005's Avatar
cynic2005
I used a pressure washer with 1500 psi. The water pressure knocked say... 75% of the grease and dirt off. If there was anything left over, I took a Skil rotary tool or a dremel with a steel brush to it. Next I would prime parts, spray three base coats of whatever color, then spray three coats of clear coat to give it a nice shine. I went over vinyl and plastic parts with "Back to Black" or a spray that acts as a finish. Then I used some type of engine shine (which is also a degreaser).
However, the engine was also disassembled so I could work with each part individually.
Old Sep 3, 2008 | 08:47 PM
MustangMike2001
Should have done a split port swap for all that work.
Old Sep 3, 2008 | 11:00 PM
cynic2005's Avatar
cynic2005
I wish I did, but by the time I learned I could do a split port swap, it was already too late.
Old Sep 3, 2008 | 11:23 PM
2000Stanglover's Avatar
2000Stanglover
Wow that is a clean motor, i took a power washer to mine and it still not that clean. Plus i'm about to enter the Army.
Old Sep 3, 2008 | 11:35 PM
jthorn9's Avatar
jthorn9
The Godfather
That's pretty clean, just be happy you still have good paint, I cleaned mine so well for shows/meets I started taking the paint off lmao.
Old Sep 3, 2008 | 11:46 PM
Vovovovan's Avatar
Vovovovan
that's a good idea with a wire brush. i should brush my compressor and alternator b/c the dust and dirt is so deep in the rough surface that it's just impossible to get it out with a teeth brush.
